With Red Bull and Mercedes among others using a full length beam wing with endplate mounted adjustable rear-wing controls, is there any benefit to having the centrally mounted pylon?
![Image](http://motorsport.nextgen-auto.com/gallery/pictures/2011/f1/test-catalunya-12mar/074.jpg)
I think they are losing time because they are struggling to balance the car. Other teams (RB and Ferrari) have evolved last years car so I think they already have a pretty good idea of how to set it up, but the MP4-26 is a totally new design.Muulka wrote:Does anyone have any idea where McLaren are losing time? Do the strange sidepods actually help? Or is the double-floor idea better?
I expect that for the time I'm on these forums I'll be answering more questions than answering, but we're all here to learn, I suppose.
So it doesn't appear to be a fundamental issue? Unless it's one that causes that lack of balance....JB2011 wrote:I think they are losing time because they are struggling to balance the car. Other teams (RB and Ferrari) have evolved last years car so I think they already have a pretty good idea of how to set it up, but the MP4-26 is a totally new design.Muulka wrote:Does anyone have any idea where McLaren are losing time? Do the strange sidepods actually help? Or is the double-floor idea better?
Also reliability has compounded any issues they have by taking track time from them, which will hurt the times.
Shrieker wrote:Have McLaren been testing their KERS these last 2 tests ? I saw nothing about that (I might have missed completely). If they haven't... Well, then. The future looks even more bleak for them
boci wrote:That is why they use wind tunnels / CFD. If they managed to even get that wrong then there must be something very wrong with their design team.tjaeger wrote:
I suppose, there would not be much of high speed air getting in there. The entry is relative close (distance, height wise) to the airbox, air right at the edge of the airbox gets disturbed/deflected and turbulent, sort of 'death stream' area, probably even Vortex.
Well, but maybe it still does, see on the outer edge of it the flow viz moves pretty well, just not on the inner surfaces. But the inner surfaces a retracted slightly, therefore there would not be high velocity on these surfaces, but overall air might still stream in very well.
That is possible but considering that the rules will again radically change for 2012 there won't be much time to reap the benefits of this wasted season.Coefficient wrote:I think Macca are suffering a mild form of Mp4-18itis. At least they're putting the flow-vis in the right places this year.
In contradiction to all the nay sayers, I think Mclaren are being very adventurous with their design. If you remember, the Mp4-18 was only conceived as a reaction to the almighty and dominant Ferraris. Mclaren were the only team that realised that they had to come up with something totally radical to compete. The problem was it was so new from and engineering perspective that they found it was very difficult to get it to work. In short, the technology didn't exist at Mclaren to make the18a work. They had bonding issues galore and when that happens you can forget the other problems.
Anyway, the 18A was the embryo of the car that eventually brought Hamilton his title. Mclaren obviously feel the need to go radical again order to catch Red Bull. So, perhaps this year the 26 will become respectable but a have a feeling the overall concept, once refined will be very good indeed.
BTW, the flow vis on the air box is fine. The heavy flow into the channel is acceptable as long as its not cyclonic. Why? Well, that's because it's designed to cool their weird exhaust which doesn't work yet but it will by Race 3.
Hopefully they'll figure out that the front wing needs to tilt longitudinally to circumvent the regs rather than just flex down!!!
The Pylon is mostly structural. However, it does limit the effectiveness of the beam wing because it splits the airflow in two which generally means that the air will lose some energy during the process of traveling from the leading edge of the pylon to the wing. It also prevents the the team designing any flex into the wing because of the bonding regs.onewingedangel wrote:I've been wondering about the central rear wing pylon - would this be compromising the concept of making the most effective use of the beam wing (which itself doesn't 'seem' as developed as others).
+1 IMOHangaku wrote:If we are to believe that McLaren were running a front wing that wasn't symmetrical, they were doing so for one reason - to get twice as much data from half as much running.
Also, if we are to believe that the airflow all around the car is affected greatly by the air coming from the front wing, it would therefore be fair to assume that this asymmetrical front wing was causing the car to be unbalanced, and therefore ensuring that McLaren weren't able to put a fast lap down in the last couple of days of testing...
... a long shot, I understand. Still seems like as fair an assumption as anyone else's thoughReally does go to show though, that nothing is as simple as read, in F1.
If the thickness of the rear wing end plates caused any serious drag issues, every team would have them wedge shapedforty-two wrote:Interesting observation.
Wouldn't the increased thickness of the RW endplates also result in a drag increase? Or do you think that centreline turbulence is more critical?
