What is the regulatory boost limit again?
568
No limit. Not needed with a fuel flow limit.
648
gruntguru wrote: ↑
11 Apr 2020, 02:18
..... Turbine power is "4 city cars".
..... Turbine power perhaps 350 kW.
isn't 350 kW optimistic ?
my city car has about 50 kW not about 90 kW
henry
324
The reference may be to Kei cars which have a maximum legal power of 47kW
My estimates are 160kW to 180kW.
henry
324
PlatinumZealot wrote: ↑
12 Apr 2020, 17:29
For what?
henry wrote: ↑
12 Apr 2020, 19:53
12 Apr 2020, 17:29
For what?
Compressor shaft power requirement. Granted this is not based on calculations but extrapolation from some other engines.
568
Turbine power should be higher than compressor power (MGUH harvests the rest.)
Turbine power = 376 kW for the following conditions.
Mass flow (air + fuel) = 1.0 kg/s (AFR = 35:1 ie Lambda = 2.38)
PR = 5.0
Inlet temperature = 1000 *C
Isentropic efficiency = 80%
Steady state flow (no blowdown).
Working from the other direction:
Mass flow (air only) = 0.97 for the following conditions
11,000 rpm
VE = 1.1 (pessimistic)
PR = 5.02
Intercooling to 27*C (optimistic)
Ambient air density = 1.2
Mass flow (air only) = 0.825 for the following conditions (Conservative)
11,000 rpm
VE = 1.0 (really pessimistic)
PR = 5
Intercooling to 47*C (realistic)
gruntguru wrote: ↑
11 Apr 2020, 02:18
WOW. Reading the fine print in that first image (It doesn't look fake). Compressor PR is 5:1. Turbine power is "4 city cars". Exhaust temp 1000+*C.
At 5:1 PR the AFR is >2.0 lambda - almost certainly stratified charge on top of TJI. Compressor power perhaps 200 kW. Turbine power perhaps 350 kW.
These numbers have moved along a lot since the early days.
Kei cars make ~68hp so ~280hp or a bit under 200kW
Snorked
Snorked
68
There's new Japanese magazine chronicling Honda moving to RedBull.
From the looks of it the four main guys at Sakura are being interviewed.
Garbage quality but it's better than nothing 😁
Maybe Amazon.jp free sample will cover these pages once the magazine is released.
568
Nice find. I would love to read the labels on those images.
The first one seems to show a progression in compressor maps from lower boost and flow to more of both in the third one.
The second image shows a breakdown of energy flows in the exhaust, MGUH and compressor. It would be nice to know where all those branches are going.
Anyone who can translate the Japanese and re-label the images?
ispano6
Snorked wrote: ↑
15 Apr 2020, 00:37
https://abload.de/img/img_20200414_232211uxj6n.jpg
https://abload.de/img/img_20200414_232138atjlp.jpg
If you provide the magazine or publication I can probably get a digital copy or higher quality scan and can translate the main parts.
Snorked
Snorked
68
It's five main guys from Sakura talking about engine development, not four #-o
Here is the link: https://www.sun-a.com/magazine/detail.php?pid=11367
Alexf1
Alexf1
GhostF1
GhostF1
110
This is pretty good news. I think this is mostly what Honda wanted to see, hopefully this keeps them in the sport until at least 2025. Should make the idea of the team becoming Honda Red Bull Racing a higher possibility for 2021 onwards.
