Because the auto manufacturers were making shed loads of money selling high NOx diesels? The higher the sticker price, the more they make on finance. Complication adds/justifies cost. Just one of the existing prejudices.
Isn't it the injector driver that requires cooling, modern ECU run cool and use low power and offer high performance.
That the ECU requires cooling (the one on my car is one side of the airbox and finned) is no surprise and in OBs and sleds I guess they use as cooling medium what is at hand (air would add bulk on OBs and sleds). But, atomisation was what held DI back as back in the 1980s when first tried using mechanical injector pumps the required (small) droplet size was unobtainable. Sophisticated injectors amplifying the pressure and/or air blast is what made DI possible.
Still it is hampered by short available injection time at high loads (if charge loss to the exhaust port is to be avoided) and the technology is complex - relative to IDI or carbs.
Though it was all pretty obvious.J.A.W. wrote: ↑12 May 2017, 01:48Marc, that light "Batam" 4T V10 of "over 1,000 HP" which your father had, do support your claim, post a citation link..Muniix wrote: ↑11 May 2017, 16:45
My father had a Batam, not all four Stroke engine are heavy 77kg for a V10 with over 1,000 HP is not heavy.
Because some one engineers one that heavy is evidence of the Engineer only.
A 26 kg single with 78hp four strokes have been engineered. 146 HP at 42 kg will be available by 2020, 180 HP with mild hybrid and multiphase combustion.
Cherry picking information can prove anything.
Also a post showing a 'kosher' dyno chart of the "26 kg single with 78 hp" 4T on test.. lets see that 'cherry'..
Since 'the proof of the pudding', even one cherry based, is in the results per taste, ah, test.. & not in 'magic' claims..
I really don't think there is much future in automotive diesel engines, or compression ignition like the GDCI gasoline direct compression ignition as they need to be built with the mass of a Diesel.
So, Marc, you are unable to provide evidence of your claims, such as a link to certified dyno charts or even weights.
Yes, well noted I was only just about to review heat dissipation of various EM drives and identifying their peak & continuous heat and power capability. Investigating peak power handling, heat dissipation and mass of light weight core less motor generator designs using advanced materials.Tommy Cookers wrote: ↑14 May 2017, 01:14well likely the electric motor's nominated peak torque is fraud as it's one that is not available continuously
the starter motor is the clear and spectacular example of this
That is why the Tesla uses different ratios for front and rear drives. Proportioning power to the most efficient motor for the given situation saving on the gearbox mass. He is not a silly man. The car acceleration g force is higher than its braking force due to the weight transfer to larger tyres on the rear.not unrelated, a gearbox is almost as important to an EV vehicle as it it is to an ICE vehicle
unless in the happy-clappy world where they pretend an ICE prime mover in an ICE/electric vehicle is a range extender
My guess going on the dual Crankshaft arrangement analysis is that the multiplier effect of pressure due to rod angle on the side thrust typically gives a net gain as the pressure differential is favourable to less total piston friction over the full cycle.btw I read today that crankshaft offset doesn't reduce piston friction, just redistributes it within the cycle
You just contradicted your self with the torque range from the impressive twin engine dyno chart being;J.A.W. wrote: ↑14 May 2017, 02:26So, Marc, you are unable to provide evidence of your claims, such as a link to certified dyno charts or even weights.
(& its Bantam, as in diminutive chook, not Batam , or Batman, or other fanciful things).
& still you don't read the data cited here..
Such as your ill-founded assertion: "...IC engines are a fraud..."
If you refer to the basic 30 year old road going 2T Yamaha twin dyno* chart posted a couple of pages back,
-not only was it capable of a peak output of ~165 hp/ltr at a low 9,000 rpm..
.. but it made over 30ft/lb torque for more than 4,000 rpm to that point.
2T engines have advanced significantly since then too, obviously.
*rear wheel power.
Marc.. again you fail to demonstrate any meaningful level of credibility.. & no data, only off-topic disorganisation..Muniix wrote: ↑14 May 2017, 06:29You just contradicted your self with torque fromJ.A.W. wrote: ↑14 May 2017, 02:26So, Marc, you are unable to provide evidence of your claims, such as a link to certified dyno charts or even weights.
*rear wheel power.
18-46 proves my statement
(eff me, they are everywhere)
in the graph I can't see of the twin 2T engine because I choose not to have my intelligence insulted by in silly childish comments...
Making claims of EcoMotors without reading their postmortem is for idiots...
I destroyed their life and will continue to rid the world of such opinionated...
That dyno data has not been released...
I may soon be able to release... ...possible due to the many advantages of dual crankshafts.
Hi Pinger, see here: http://3cyl.com/mraxl/performance/perftech.htm
Not sure I agree with his analysis of how -ve suction from exp' chambers aids crankcase filling at higher rpm - other than any residual vacuum remaining when the transfers close. It can't draw straight through from cylinder to inlet (like a reeded motor can) as the inlet port is closed around that crank angle. Suspect he is overlooking inertial effects.J.A.W. wrote: ↑14 May 2017, 08:24Hi Pinger, see here: http://3cyl.com/mraxl/performance/perftech.htm
This shows how amenable a basic 2T is to thoughtful, but simple (& inexpensive, by 4T values) performance mods.
The old Kawasaki 750/3 thus ~doubles its output, but not at the cost of a 'peaky' or catastrophically hard - tune..
Yep. I think the tide has turned against Diesel but I doubt the manufacturers know which way to jump right now.Muniix wrote: ↑13 May 2017, 22:43I really don't think there is much future in automotive diesel engines, or compression ignition like the GDCI gasoline direct compression ignition as they need to be built with the mass of a Diesel.
The extra mass, expense and complexity required due to CI with high acoustic combustion energy with Diesel and gasoline and emmisions will not be cost effective when EU 7 emmisions are reached.
P, the basic convention is to show the TQ/HP cross at the maths constant of 5252 ( where possible, most diesels wont).Pinger wrote: ↑14 May 2017, 10:09
Why, when he shows power and torque curves plotted with the Y-axis calibrated in hp and lb.ft, do the lines not cross at 5250 rpm (his cross at 7000)? The RDLC YPVS plots cross at 5250.
What do you use for pipes on your 750 J.A.W.? Three separate pipes or three-into-one?
P, a couple of things..Pinger wrote: ↑14 May 2017, 10:49
For sure they have GDI but are they going to wait until particulate filters are mandated before fitting them...
Full electrification isn't an option for everyone as many (especially in cities where they are of most benefit) do not have access to home charging. At the workplace possibly, but what to do at weekends and holidays? There is also the environmental aspects of mining the required materials. For the manufacturers though, they can market electrification as a new technology and price commensurately. The same can not be said for a 2T ICE - unless it is buried within a heavily electrified vehicle. And still I haven't seen an available off-the -shelf viable 2T.
There is of course the possibility of electric vehicles being hooked up to the electricity grid at all times other than when being driven, giving said grids storage capacity they have hitherto only dreamed of. Smoothing out the demand peaks and troughs easing generation matching over a 24 hour period is there to be had - but so far, no takers.
Are we agreed Muniix that the TJI/lean burn concept (applied to 4T) is the most likely to succeed in the short to medium term?
