How do you bypass the gearbox? Am I missing something?
Edit: I just saw your updated post
The electrical losses of such a system would be much higher than the frictional losses in the drive train. Besides, an electrical machine in the final drive area would violate the rules, which allow only for an MGUK directly coupled to the engine.GrandAxe wrote: ↑07 Aug 2018, 01:03In summary; within the rules, the ICE can continuously drive the MGU-H, which in turn can continuously drive the MGU-K (even when not harvesting), since the rules allow the MGU-H to provide the MGU-K with an unlimited amount of energy.
This would allow a gain in power by bypassing the friction generating parts of the drive train eg. gearbox etc.
There is no need for continuous electrical driving of the MGUH by the K. The crankshaft power robbed by the K to do this is far more valuable than the waste heat that drives the turbine.GrandAxe wrote: ↑07 Aug 2018, 01:45I just saw this.
It makes bypassing the gearbox impossible. However the loophole for continuous driving of the MGU-H is still possible.5.2.3 The MGU-K must be solely and permanently mechanically linked to the powertrain before the
main clutch. This mechanical link must be of fixed speed ratio to the engine crankshaft.
The loophole is that only mechanical connections to the MGU-H are regulated. Electrical connections are not, therefore the MGU-H can be directly driven by an alternator, not just the turbine. With that, the engine can continue running at as optimal speeds as possible, even under braking.gruntguru wrote: ↑07 Aug 2018, 02:59There is no need for continuous electrical driving of the MGUH by the K. The crankshaft power robbed by the K to do this is far more valuable than the waste heat that drives the turbine.GrandAxe wrote: ↑07 Aug 2018, 01:45I just saw this.
This part I got wrong, because I hadn't seen the relevant regulation; but I corrected the notion in my very next post.
In the energy flow diagram, Appendix 3, the energy flows for ancillarys are shown. My reading of this is that:GrandAxe wrote: ↑07 Aug 2018, 01:03I posted on the equivalent Ferrari to this, that it should be possible to drive the MGU-H from the engine through an alternator (since there are no limits to electrical connections to the MGU-H, the rules only cover mechanical ones).
The only (somewhat contentious) limiting factor according to the discussion on that thread is the 120kw limit the MGU-K is allowed.
IMO, what you want to be doing is using the MGU-H to constantly drive the MGU-K. ALL the heat, flow, and noise coming out the exhaust pipe, is wasted energy. In an ideal world you would use the MGU-H to recover all of it and feed it to the MGU-K.
IMO no, not really. What you suggest is most energy efficient, but it’s not the quickest.
That's a valid point indeed. However, the MGU-K is allowed a 120kw input and a 120kw output; if input and output can be employed simultaneously, then a total 240kw can pass in and out of the MGU-K continuously (in ideal settings). This should allow 120kw to be piped through the MGU-K at a continuous rate (again, in ideal settings) from the engine to the MGU-H via the unlimited path between MGU-K and MGU-H. Of course, in less than ideal settings (e.g. optimisations for overall efficiency or other peculiarities), energy flows might be interrupted.henry wrote: ↑07 Aug 2018, 09:47In the energy flow diagram, Appendix 3, the energy flows for ancillarys are shown. My reading of this is that:GrandAxe wrote: ↑07 Aug 2018, 01:03I posted on the equivalent Ferrari to this, that it should be possible to drive the MGU-H from the engine through an alternator (since there are no limits to electrical connections to the MGU-H, the rules only cover mechanical ones).
Engine ancillaries are governed by the MGU-K restrictions.
Other ancillaries can only receive energy from the H or K or ES, they can’t send.
Would an alternator connected to the MGU-H not be constrained by this?
I may be missing something, but if you are doing this simultaneously, wouldn’t net output be 0 kW? Why do that at all and incur the losses (FIA set this at 0.95) to get net 0?
