johnny comelately wrote: ↑02 Mar 2023, 01:46
wuzak wrote: ↑01 Mar 2023, 09:56
johnny comelately wrote: ↑01 Mar 2023, 02:12
I have questions regarding energy density, it would make the most sense to have the highest as this would be the least weight which is a penalty either on the track or road. Therefore the flow rate would be less (depending on the stoichmetry of the new fuel, which could be anything!) but of course this relates to engine capacity which would be smaller.
Engine capacity does not change.
But, yes, higher density would be preferred.
The allowed range is 38MJ/kg to 41MJ/kg.
That equates to 78.9kg/hr fuel flow rate for energy density of 38MJ/kg and 73.2kg/hr for 41MJ/kg.
Or around 7.3% less mass for a given amount of energy.
So you are going from 100kg/hr to say 79kg/hr staying at 1600cc?
Currently at 1.25 lambda
which means going 1.6 lambda (roughly) maintaing the 1600cc, is the boost coming down by 25% ?
how is this possible?
Yes, 1.6L 90° V6, maximum fuel/energy flow rate is achieved at 10,500rpm, after which it remains constant to the rpm limit of 15,000. And the same minimum mass as the current regulations.
Maximum compression ratio has gone from 18:1 to 16:1.
From the 2026 regulations:
5.5.2 Engine inlet air pressure must be less than 4.8 barA at all times. The pressure of the air will be measured by an FIA approved and sealed sensor located in an FIA approved location situated in the engine inlet system.
From what I can see at the moment, there is no limit to boost/MAP in the current regulations.
