McLaren MCL36
_cerber1
266
Re: McLaren MCL36
Play of light. In my opinion, the nose has not undergone any changes.
djos
113
Re: McLaren MCL36
_cerber1 wrote:
28 Jul 2022, 07:26
On closer inspection I think you are correct. The newer photo is slightly out of focus which makes the blend look smoother than it is.
"In downforce we trust"
Mansell89
Mansell89
Re: McLaren MCL36
djos wrote:
28 Jul 2022, 05:44
continuum16 wrote:
28 Jul 2022, 05:24
First picture from Budapest (via Albert Fabrega)
https://i.imgur.com/iIYVGIf.jpeg
Not sure if I'm seeing things, but to me it looks like the nosecone is shorter. Not sure if that is the case, or even if that was the case in France.
It's definitely different from the French spec nose (below), it seems to have a smoother profile.
https://i.imgur.com/Lk6z8fh.jpg
Without a doubt there is a difference. There is a pronounced “slope” or change of angle on the bottom part of the nose
Re: McLaren MCL36
Would it be beneficial enough for the money spend ? Noses are not cheap...
mwillems
45
Re: McLaren MCL36
mclaren111 wrote:
28 Jul 2022, 11:46
How much of the nose would need to be rebuilt to create that change, or would the wings and crash structure be kept and just the carbon fibre bulk be updated and the wings reattached?
It's an odd little change though, I wonder what affect that will have.
-Bandit
Re: McLaren MCL36
mwillems wrote:
28 Jul 2022, 12:27
mclaren111 wrote:
28 Jul 2022, 11:46
Aaah... I see what you mean... :D
mwillems
45
Re: McLaren MCL36
mclaren111 wrote:
28 Jul 2022, 12:35
mwillems wrote:
28 Jul 2022, 12:27
mclaren111 wrote:
28 Jul 2022, 11:46
No idea if that will give enough strength in the join of the winglets to the body of the nose but I suppose they could.
But the change looks almost inconsequential, unless something has changed inside the nose too?
-Bandit
RZS10
359
Re: McLaren MCL36
McLaren did not really have any vanity panel on top of the actual crash structure like some other teams if this image (mirrored in orange outline) is anything to go by - it all seems structural up to where the seam used to be (in blue outline) ... so if there was a change towards more of a step design (green line) it would be above the seam = meaning a completely new nose?
Unless of course they added the bump on top, making the nose higher (yellow) ...
Either way, the very first image from the side will tell us what's what.
pipm1
pipm1
Re: McLaren MCL36
I can't see a difference, it is just that the out of focus blue is more prominent than the out of focus black carbon, making the latter look like it is concave (as per the red line above).
MrGapes
34
Re: McLaren MCL36
Changes to the diffuser this weekend
_cerber1
266
Re: McLaren MCL36
MrGapes wrote:
29 Jul 2022, 11:47
+Front Brake Cooling
_cerber1
266
Re: McLaren MCL36
Re: McLaren MCL36
The gaps between the Top Two Flaps seems bigger ?
Re: McLaren MCL36
What has changed in the front to warrant the aero strakes ?
RZS10
359
Re: McLaren MCL36
They've changed the front brake cooling ducts
Whether that is reason enough to run those?
