Erunanethiel wrote:Andres125sx wrote:olefud wrote:
As a generality, trail braking is a function of the ability to accelerate vs. the need to carry speed through the corner. Obviously acceleration is diminished out of a high speed corner.
Exactly, depending on the corner it may be beneficial or not
So which kind of corners is it benefical for and which kind it is not? Sorry I couldnt understand because of my English and there may be other people that couldnt understand too.
Thanks.
On long corners it´s not beneficial. For trail braking you turn to face the inner kerbs sooner to be able to continue with the car straight (almost) and keep the foot on the brake longer (so you can brake later), but when you release the brake pedal and turn, you´re not on the outside, so your line throught the corner need to be thighter. This means you need to turn the wheel a little bit more so your min speed thought the corner is lower. If it´s a short corner and it´s just an moment, and you are on the throttle again, it´s beneficial because of the huge acceleration of F1 cars, but if it´s a long corner where you can´t hit the throttle that soon and need to keep the wheel turned some seconds, then lowering your min speed is not beneficial because you lose more time through the corner than you won braking a bit later
I hope it makes sense, english is not my native langueage either, and I struggle with these technical explanations
