*the strenghts of mp4-27 were totally diferent solutions.
sorry
No it was notmclaren_mircea wrote: About Mclaren, I'm a little afraid with the pull-rod suspension, and with the possibility of Mclaren going for a higher nose. Because that kind of suspension was a mess for Ferrari
Name one team apart from Ferrari that does not lack experience with this? Also that is the same with everything, so to use this as an excuse for why theywouldnt incorporate it on their car, it is a bad one.and Mclaren lacks experience with that kind of suspension in the modern era of F1.
Why should that be the case?I hope it is not another "octopus exhaust" case in performance for Mclaren.
Doesnt mean that maximum tub height isn't the best solution.And with the nose, Mclaren for some years developed good cars with low-noses.
The rear pull rod as Newey explained is by far the best solution for the rear with the current diffusers.Lycoming wrote:Mclaren have used a pullrod rear since the -26. I still can't believe people honestly think Ferrari's problems were related to their choice of pullrod suspension.
They spend years with a low nose, until they decided during the season that they had to change their philosophy. IMO, it's more feasible they want to continue this new path and raise the nose again.4. Regarding the nose, Mclaren spent years (NOT a single year, or a couple of months) refining and developing relative low-noses. With so much knowledge and experience in this area, they could easily integrate a moderate low-nose in a winning championship car, without the obligativity to understand, learn and develop a new type of nose.
If I am correct, they raised the nose as high as possible within the limits of the chassis they had back then. I can't tell if they were bothered for raising it even more and in turn construct a new, higher chassis. If they weren't, then most likely the chassis will not be raised either this year. If they were looking at raising it, but came to the conclusion it wasn't worth the trouble to construct a new chassis, then they might do it this year.mclaren_mircea wrote:@turbof1
You are partially right with the nose. But the nose that they adopted in the second half of the season I don't think that is a properly high nose. It's somewhere "between". It's a refined form of their original nose. It's higher than the first variant, but it's rathar an evolution. The basics and the structure of the nose does not depart significantly from their conceptual thesis, and is something much more complex than a typically higher nose. But I don't have the pretension that I hold all the truth. I may be very well wrong with the nose and a true high nose can be a real advantage for mp4-28, as well as the pull-rod, but I'm here to learn about F1 and to change ideas about the Mclaren car with other supporters of this team, in a constructive debate
That is correct. Their wind tunnel is quite dated now. Its mostly used by Marussia and other Mclaren areas like GT3 and Automotive. The new Applied Technology building across the roundabout will house a state of the art wind tunnel, until then I guess its Toyota.mclaren_mircea wrote:but I read right now an article on http://www.omnicorse.it, that Mclaren is using the Toyota wind tunnel (which is 60% scale) because the Mclaren wind tunnels for the f1 team are only 50% scale. Please if you now something on this topic post here.
Perez is more similar to Button then Hamilton was, isn't it? McLaren now atleast can build a car that is more designed towards one single driving style (although Hamilton probably could handle a pure Button car like a charm). That should atleast give less headaches and more focus towards making the car faster.KATO wrote:Pérez and Button should look good right out the Box at Melbourne but it is true that Button is the kind of driver that needs a great car. However I strongly believe he will have it the Mp4-28 is being designed to suit him. So look for Button to be similar to his Championship season... I hope it's enough and I am really looking forward to what button and Perez can do..
