569
Re: Ferrari Power Unit
Separate control of left and right bank throttles and different fuel mixture to each bank as required.
Edit. Right throttle is open more than it should be and flagged in red. Right bank is running leaner than left.
GoranF1
GoranF1
151
hattrick wrote:telemetry from Haas F1 team:
https://pbs.twimg.com/media/CcpacV7WoAAyo9g.jpg:large
Source
Can someone analyze?
they are using windows 95... :D
Zynerji
111
Source
I think it's XP in simple mode...
ferkan
ferkan
31
Whoa Ferrari will be trilled with Haas and Sauber.
Stargazer
Stargazer
GoranF1 wrote: they are using windows 95... :D
Nope, it's Windows 7, possibly Embedded version. WinEmbedded is an edition you can customize and cut as you want in order to create an OS for the specific device/function (still sucking if compared to embedded Linux by a ton of reasons).
Update: it's not Embedded. It's usual one, it even runs antivirus.
irsq4
irsq4
-1
gruntguru wrote:
PlatinumZealot wrote:Variable trumpets confirmed.
135 bar fuel. (could be just start up pressure though).
96*C fuel? What?
TFuelRailGDI = 96.7
TFuelRailGDI 1= 46.1
TFuelRailGDI 2= 96.7
Not surprisingly, they are running heated fuel (as did Honda in the RA168e). This system looks even smarter. Seems they have two fuel supplies - one at the max temp they need (TFuelRailGDI 2) and one near ambient (TFuelRailGDI 1). By varying the mix they can inject at any desired fuel temperature (TFuelRailGDI ) in between, and change the temperature - almost instantly.
By varying fuel injection temp (besides pressure), fuel spray properties are varied ie spray atomization. Sauter Mean Diameter is smaller (smaller droplets) when fuel is injected at higher temp., ref. Tagung Diesel- und Benzindirekteinspritzung
Mr.G
34
I'm not expert (not even close) but it look's for me like the engine is turned off. Air pressure sensors shows 1 bar...
hurril
hurril
Mr.G wrote:I'm not expert (not even close) but it look's for me like the engine is turned off. Air pressure sensors shows 1 bar...
The RPM though?
Mr.G
34
The RPM though?
#-o Don't realize that. So probably idle (throttle 0%) ... 3400rpm sounds like that... It look's like the car is in garage.
650
96*C fuel? What?
TFuelRailGDI = 96.7 TFuelRailGDI 1= 46.1 TFuelRailGDI 2= 96.7
diesel fuel has high viscosity and so has high viscosity change with temperature ?
SI fuel does not
the high-toluene fuel of the 168e era (having a high BP) required controlled heating to improve/standardise its vapourisation
Cosworth talked about charge conditioning (being a reason why PI was good and DI unnecessary in N/A F1engines)
Honda research found PI and charge heating enabled efficient combustion of very lean (AFR 2) homogeneous mixtures
maybe F1 is adjusting fuel temp for similar reasons
Kalsi
Kalsi
31
Source
As gruntguru noticed... throttle seem opened in different ways between left and right and it seems the engine is idle with the car in the garage...
I can also notice a TExhaustL = 282°C and TExhaustR = 300.5°C
So now i have two questions...
- Could those be the new wastegates exits temperatures?
- May the almost 20°C temp delta be related to some sort of testing of the variable-length intake manifold system? (Different settings between left and right)
F1NAC
172
Source
maybe temps from left and right exhaust manifolds
pgfpro
75
IMO It looks like the
pThrottleL 0.568 bar
pThrottleR 0.574 bar
are left/right intake MAP sensor readings
Based on the A/F ratios average and MAP average the engine is flowing around 3.07 lbs/min of air and 0.0552 lbs/min of fuel
at 3377rpm.
building the perfect beast
Frank_
Frank_
half a bar of vacuum post throttleplate eh, that turbine is barely coasting along @ 3377rpm
toraabe
toraabe
Source
Win 7 classic mode.
