Alpine A521
Re: Alpine A521
Interesting
F1T
Administrative bot
Alpine already switching to more compact rear end
Lots of people were stunned by Alpine's decision to fix a bulky airbox on the A521, but the team have already run their new car today with a new, more compact design that sees the rear end of the car considerably slimmed down. Along with the airbox that now tapers down more more quickly, the sidepod air outlets are smaller, leaving a lot more room low above the car's floor for clean airflow.
As the image shows, Alpine were focusing on front end aero on Friday morning with a rake fitted in the front wheel's wake. Today, with the updated rear bodywork, a rake was fitted at the back of the car as Alonso made his debut with the A521.
The update however doesn't change anything about the obvious design decisions that were made at Enstone. As confirmed by Alpine's Technical Director Marcin Budkowski on Saturday morning, the team opted to fit more components in the airbox area to be able to slim down the sidepods in an attempt to reduce downforce losses as a result of the narrowed floor.
“It’s a technical choice,” he said. “We found that slimming the sidepods was a positive direction, which is nothing new really. So we’ve repackaged and relocated some of the bulky things in the car and put them behind the air inlet.
“Yes, it gives a fairly spectacularly bulky shape on the car, but we found it works for us.”
Of course, no gain is for free, and Budkowski concedes there were a few compromises to be made.
“There are centre of gravity compromises but usually the aero performance wins over weight and centre of gravity."
Overall, this is a continuation of the design direction that was already overly obvious on the {Renault} R.S.20, resulting this year in smaller sidepod air inlets - the outboard top edges have been more rounded - and a very "natural" shape of the sidepods in general.
Re: Alpine already switching to more compact rear end
The one million dollar question is: which cooler/bulky element did they move the top center :?:
F1T wrote:
13 Mar 2021, 17:10
//f1tcdn.net/images/development/2021/ba ... idepod.jpg
Today they ran the standard roll hoop cover length that they used each year since 2018.
Roll hoop is basically the same since 2018. Yesterday is the fist time they extend its cover laterally.
Re: Alpine A521
Hungary 2020- Bahrain 2021
jagunx51
185
Re: Alpine A521
jagunx51 wrote:
12 Mar 2021, 12:07
what is behind the airbox? that is fat
https://s3-eu-west-1.amazonaws.com/cras ... 152568.jpg
What’s behind Alpine's jumbo airbox
https://www.motorsport.com/f1/news/what ... x/5707809/
But the first thing to say is that the airbox and roll over structure of the A521 has not changed if we compare it with the RS19 or RS20. Instead, it’s the bodywork behind that’s been significantly increased in size.
The reasoning for this, although it might sound odd at first, is predominantly to mitigate the incoming regulation changes that narrow the floor and rear brake ducts and see the lower portion of the diffuser strakes lopped off.
Whereas the rest of the grid have pushed-on and developed the downwash style sidepod arrangement which generally results in the airflow running over the top of the sidepod and meeting with the floor as quickly as possible, the A521 has an arrangement more akin to what teams used in the pre-hybrid era.
This is for a more heavily undercut frontal section and higher waisted sidepod along the entire length.
This creates more space between the sidepod and the floor in order that the team deals with the issues created by the new regulations in its own unique way.
However, to achieve its aerodynamic goals, the team had to rethink the cooling architecture of the car, resulting in the radiators and other hardware housed within the sidepods having to be repositioned.
The arrangement that Renault has run in previous years has already seen a great deal of that hardware packed in around the powerunit due to the makeup of its cooling package. But with even more hardware to deal with, the region has increased quite dramatically in size.
So, in essence, the changes are driven by the regulation changes and are simply Alpine’s way of dealing with these issues, whilst trying to recover as much performance as possible, without damaging the car’s overall performance envelope.
Irrespective of the genuine technical reasoning behind the changes, it’s easy to draw comparisons with a variety of different airbox and engine cover solutions in Formula 1’s past...
Re: Alpine A521
diffuser wrote:
13 Mar 2021, 22:37
@Blackout, Guess there will not be a shortage of pics of RBR without an PU cover ???? :D
:mrgreen:
jagunx51 wrote:
12 Mar 2021, 12:07
Atleast this
https://i.imgur.com/Znbv8rM.jpg
I wonder what other cooler did they remove from the sidepods this year... only two air-air intercoolers + 1 engine water rad + 1 engine oil rad remained in the sidepods since they moved the ERS coolers to the centre of the car in 2018...
Re: Alpine A521
There is something odd at each side of the gearbox... looks like winglets... an internal aero fairing?
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Another floor option
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Front of floor edge compare 2020 vs 2021
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Rear corner comparison 2020 vs 2021
TimmTurbo
TimmTurbo
Re: Alpine A521
Man that car looks ugly.... the airbox is out of any proportion. No wonder why nobody wants to get that PU
bucker
bucker
Re: Alpine A521
TimmTurbo wrote:
14 Mar 2021, 17:09
Because PU is reason for bulkier look....
GoranF1
GoranF1
151
Re: Alpine A521
Livery and Reliability very good. Question marks over pace and speed.
outer_bongolia
Re: Alpine A521
Blackout wrote:
13 Mar 2021, 10:27
They are running the shorter roll hoop cover today + the smaller hot air exits at the back of the car
https://i.imgur.com/6oLkfVF.jpg
Wow. Comparing these pictures, Ocon looks like he’s sitting a lot higher than Alonso. I wonder what it does to the air coming in from the lower inlet.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
cheeRS
cheeRS
Re: Alpine A521
outer_bongolia wrote:
14 Mar 2021, 20:15
Blackout wrote:
13 Mar 2021, 10:27
He sure does! Wonder how that effects the protection from the halo 😳
Human history is the long terrible story of man trying to find something other than God which will make him happy.
