wowgr8 wrote: ↑13 Mar 2021, 09:31
So more Red Bull style? Do you think the aero benefit will still be sizeable? Or will it be smaller than we saw with the Mercedes?
Also, Ferrari apparently spent their tokens on the gearbox/gearbox casing, how are they then allowed to play with the suspension like this? Doesn't changing rear suspension require a different set of tokens? I don't understand the token system fully
Maybe it's one token for the box and another for the suspension structure, but you end up having to use both because if you change the box you are gonna need to change the suspension too.
Red Bull now is very similar to the Merc, Ferrari is a lot more conventional than they are, for whatever reason didn't think that was the way to go.
Some people have mentioned that the Merc suspension lower arm attaches to the impact structure and not the gearbox so teams would need 3 tokens to fully reproduce it, yet Red Bull managed to do a very close fac-simile, so i'm not buying that... Ferrari just went a more conventional direction.
