I know all this stuff in portuguese, I'll see if I find something in english to post.
This is completelly wrong, you can take my word for granted here.
And entirely, totally wrong.manchild wrote:I thought it is more than logical. A rectangle or a pipe shaped object, whatever, which has diameter of 5 inch is much stronger than one with diameter of 50 inches if they are made of identical thickness material. So, if thickness of current Ferrari nose is for example 1 inch and if the cross section is reduced that would allow thinner walls (less weight). As simple as that.
Because an aluminium drinks can is designed to be DISPOSABLE. A beer keg has to be more durable because they're supposed to be re-used. They also get a lot rougher treatment.manchild wrote:Why make it 3 or 5 mm thick when it can withstand force being less than 0.5 mm thick? Keg would collapse if made as thin as can but can doesn't. Get my point?
That's got nothing to do with logic. Smaller tube regardless on shape with walls of same thickness as larger tube can withstand greater forces than larger tube. Have you ever seen a waterworks 1/2 inch pipe that has thicker walls than 2/3 pipe?shawness wrote:And entirely, totally wrong.
The compressive strength of a tube is directionally proportional to the amount of material in the section. For the sake of simplicity, if we say that the nose is completely square in section, 200mm on a side and 10mm think, you have a material section of 76cm2. If you narrow the tube to 150mm on a side while maintaining the 1cm thickness, you have a material section of 56cm2. To maintain the same strength, you have to increase the wall thickness.
What load of stuff? Since top of the nose would be lowered, the walls of the nose could be thinner whith upper extensions very thin or even hollow. That little wing not bigger than A4 paper wouldn't increase weight to any amount that would be worth mentioning relative to reduction of weight trough possibilities emerging from smaller cross section.shawness wrote:if you weren't slapping a whole load of stuff up on top for your wing.
No, because aluminum drinks cans have been designed to cost as little as possible and to be able to withstand transportation and inner pressure. When aluminum cans were introduced no one knew what recycling is or about garbage disposal problem. The first canning facility was established in 1813, while first drink cans were introduced in 1909. By October 1937, some 23 breweries were producing over 40 different brands of canned beer!shawness wrote:Because an aluminium drinks can is designed to be DISPOSABLE.
The issue isn't that we're saying it's impossible, it's just that manchild was claiming it'd be lighter, even though he was adding structure - which is impossible. You could certainly build manchild's ideas, you just wouldn't want to.teecof1fan wrote:I still don't understand all the fuss about the integrity of manchild's most recent design idea. It sounds like people see it as taking a big part out of the nose, but really it's just adding a little piece on top. Just take the nose and add the bridge part to it. Maybe they would lower the nose to add the piece, but that doesnt mean it's any weaker. Like I said in my other post, we see tons of different nose shapes but they all pass the crash tests. Now the original idea with the hole running up through the bottom and out the top presents a challenge, but don't you think that the Ferrari Formula One Team, with all their brainpower, manpower, and money, could figure it out
Yes I claim that tube of smaller diameter requires less material in walls. Prove me wrong.shawness wrote:The issue isn't that we're saying it's impossible, it's just that manchild was claiming it'd be lighter, even though he was adding structure - which is impossible. You could certainly build manchild's ideas, you just wouldn't want to.
Now, how about reading the topic from page oneshawness wrote:The concept that Ferrari are supposedly experimenting with is NOT what manchild has been suggesting...
You can try arguing the point as much as you like, but you're still WRONG. This is PHYSICS. You can't argue the laws of physics around to your point of view, even on the internet!manchild wrote:That's got nothing to do with logic. Smaller tube regardless on shape with walls of same thickness as larger tube can withstand greater forces than larger tube. Have you ever seen a waterworks 1/2 inch pipe that has thicker walls than 2/3 pipe?
You're wrong. They have to support the front wing, which at full speed is like having four fully-grown adults hanging on the nose.manchild wrote:The only structural demand in front of F1 nose is to pass FIA crash test. If it can pass it than nothing else matters structure-wise since they are already thicker than necessary for no other reason but passing FIA crash test.
I already did, in very simple terms. Try actually reading what I said and understanding it before making yourself look like an idiot by arguing against the laws of physics.manchild wrote:Yes I claim that tube of smaller diameter requires less material in walls. Prove me wrong.
Wrong. A balloon bursts when you over-inflate it because you're exceeding the tensile strength of the rubber. You'll probably get on to that once you graduate from elementary school...manchild wrote:Do you know why a balloon bursts when you inflate it too much? Because its walls become thinner as the pressure increases. To be able to inflate it with more air you'd need a thicker walls and vice versa. It's elementary school stuff!
I've read the whole thread from the beginning several times, with interest. If you read my post carefully, you'll see that I was explaining why both your ideas aren't going to work, and how your FIRST idea is different the supposed Ferrari concept.manchild wrote:Now, how about reading the topic from page one![]()
This idea with lowered nose top and additional wing is second idea presented in same thread. If you read topic from page one than there'd be no need for me to explain you that.
That's exactly what I claim you're in collision with - the basic PHYSICS.shawness wrote:You can try arguing the point as much as you like, but you're still WRONG. This is PHYSICS. You can't argue the laws of physics around to your point of view, even on the internet!
Compare thickness of the nose cone walls before and after FIA introduced obligatory crash test. Front wing carried even greater loads back in days when cars were 2 meters wide but the nose walls were much thinner.shawness wrote:You're wrong. They have to support the front wing, which at full speed is like having four fully-grown adults hanging on the nose.
Tensile strength of the rubber is limited by thickness. If it was thicker it wouldn't burst as same pressure.shawness wrote:Wrong. A balloon bursts when you over-inflate it because you're exceeding the tensile strength of the rubber.
I've never claimed that I know what Ferrari is up to, I was only guessing, but you seam to claim you KNOW. So, please present to the F1 world official info about Ferrari concept since you deny my suggestions, autosport, Piola and who knows else.shawness wrote:...and how your FIRST idea is different the supposed Ferrari concept.
I don't know anything about the Ferrari concept beyond the same rumours everyone else has heard - that's why I call the the 'supposed' Ferrari design! For the record, I don't think it'll happen, as the benefits are far too marginal. My comments were that the only reason that you would bother putting a hole there (pressure relief) is different to anything you've suggested.manchild wrote:I've never claimed that I know what Ferrari is up to, I was only guessing, but you seam to claim you KNOW. So, please present to the F1 world official info about Ferrari concept since you deny my suggestions, autosport, Piola and who knows else.
(Although I think doing that in forum instead of selling that exclusive story to some F1 magazine wouldn't be a smart thing to do.)
1. Ferrari never said anything about it.shawness wrote:Ferrari (and Autosprint, Autosport et al ) are talking about is a SMALL duct just behind the rear edge of the front wing, designed to bleed off some of the high pressure air where it hits the bottom of the nose and extend the downforce-generating area of the low pressure under the nose forward slightly. Other than the fact it features a hole in the nose, it's a fundamentally different concept. Saying it's the same idea is like comparing a hairdryer and a jet engine.
