To bad they have said no to ground effects..jenkF1 wrote:True, the only way to generate good racing is remove the heavy reliance on the front wing. In fact, remove wings all together, bring back ground affect tuned to leave as little turbulent air as possible. DRS should only be a temporary fix. And I say let the driver in front use it.HampusA wrote:When the cars a designed the way they are there is no other way..
I think the DRS advantage only aplified the issue in Turkey, I dont expect there to be that bigger advantage for the rest of the season. That is if the FIA shorted the DRS zones.
In some sense i can agree because FIA would not have any control over it or know just how much downforce the cars would create.
But on the other hand FIA could design a floor with a fan that all the teams have to use and only letting them focus on the rest.
Either way, we need to move away from this much aero or come up with a solution that does not disturb the airflow so much behind the car.
