Seeing this now, it's quite possible it could be doing something that is far from what we thought. We need to see inside the nosecone now.
Remember the flap adjusters from 2009?
I think this system is like that.
No, please expand.ringo wrote:Remember the flap adjusters from 2009?
I think the carbon cover was just to hide the pipes so they could not be photographed. Two small push in connectors at the top. However it is quite a complex shape with detail down the sides that conflicts with it being merely a photo shield. Alternatively there are two pieces- the bit at the top which is permanent (but stripped in the photo like the brake tanks) and the photo shield which is just the flat plate closest to the camera.Owen.C93 wrote:Still not satisfied, I want a picture of the carbon cover to see what it does with those tubes, as well as a look into the nose cone
It is not 'expand' that word means increase in size or volumehardingfv32 wrote:No, please expand.ringo wrote:Remember the flap adjusters from 2009?
Brian
not a grammar school heresiskue2005 wrote:It is not 'expand' that word means increase in size or volumehardingfv32 wrote:No, please expand.ringo wrote:Remember the flap adjusters from 2009?
Brian
The word u should use is explain
Better exhaust layouts not only improve heat buildup, but I suppose that they also maintain an uniform temperature around the surface of the tyre. That's, IMO, the only fundamental difference between some cars and the others.prince wrote:Now that we are sure that W03 is facing tyre problems. Let everyone pitch in here and provide thier understandings and suggest how can W03 be improved in the area of tyres.
Problem Statement: Tyre degradation.
Perceived cause: Tyres are not getting into optimum range of operating temperature, which is causing heavy degradation. THE ISSUE IS NOT OVERHEATING.
My solution: As we can see, teams who have a better exhaust layout, in someway are helping the tyres to heat up by exhaust gases. The best way to put temperature in tyres is without causing tyre wear. By weaving on the circuit, tyres can be warmed up, but they degrade. The need of the hour is to put the temperature in without causing degradation. In current scenario, there is no way, I think they can resolve the issue by changing the setup. MGP has to copy the exhaust layout of Redbull or McLaren. By blowing the exhaust gases, they can warm up the tyres, without causing degradation. I don't see them fixing it before Spanish GP.
Any other ideas?
