Awesome race analysis by SomersF1, including some pretty cool technical insights (regarding brake temperature management, etc.).
http://www.somersf1.co.uk/2019/08/somer ... tical.html
Thanks. i generally have a lot of time for Matt Somerfield but there were a couple of nonsenses:zibby43 wrote: ↑05 Aug 2019, 22:23Awesome race analysis by SomersF1, including some pretty cool technical insights (regarding brake temperature management, etc.).
Well it's the opposite isn't it: more grip from new tyres means you can increase the load on the brakes! Tho the amount of energy is the same so it just means they can brake later and harder for less time but the total heat energy is the same. edit or What he probably means is they can corner faster so they don't have to dissipate so much heatEffectively the grip that’s being generated will slow the car more effectively, meaning you can lean on this to reduce the load on the brakes.
The surface area is exactly the same obviously Matt! It gets harder to keep them alive because there's less movement within the material generating heat, and more importantly it's easier to wear through the 3mm grip layer and end up on the inner coating.The task at hand was made a little more difficult still for Verstappen, due to the thinner gauge tread used by Pirelli this year, as there’s less surface area on the tyre to retain heat, especially at the end of the tyres life when staying in the operating window is even more critical.
The heat load is lower because your arrival speeds are similar but your cornering speeds are higher - so you scrub less energy off, also because you're braking in a shorter interval you see higher peak interface temps (which dissipate quicker to radiation) versus brake core temperatures.izzy wrote: ↑06 Aug 2019, 00:31Thanks. i generally have a lot of time for Matt Somerfield but there were a couple of nonsenses:Well it's the opposite isn't it: more grip from new tyres means you can increase the load on the brakes! Tho the amount of energy is the same so it just means they can brake later and harder for less time but the total heat energy is the same.Effectively the grip that’s being generated will slow the car more effectively, meaning you can lean on this to reduce the load on the brakes.
The Mercedes in Hungary used a new fuel to vitaminize the Phase 2 power unit that debuted in Canada, but which had not given the impression of being the most powerful engine in the Circus, punctually dominated by the 6-cylinder Ferrari.
According to the rumors that leaked from Brixworth the contribution of the new petrol would have been of 18 horses: an impressive quality leap, which is worth much more than an engine development, because obtained only with chemical components and without requiring intervention on the mechanics.
It seems that the very secret molecules that make up this new fuel are the result of a collaboration between Petronas and a small German laboratory that has developed a new synthetic gasoline perfectly in line with the FIA regulatory requirements, but capable of a distinct calorific value higher.
Regarding the brakes/tires point, was he referring to the fact that a fresh tire has more bite/grip? Better grip means better and more efficient braking performance. That has to help with managing the temps, as sliding around on older, slicker rubber often requires additional braking input.izzy wrote: ↑06 Aug 2019, 00:31Thanks. i generally have a lot of time for Matt Somerfield but there were a couple of nonsenses:zibby43 wrote: ↑05 Aug 2019, 22:23Awesome race analysis by SomersF1, including some pretty cool technical insights (regarding brake temperature management, etc.).
Well it's the opposite isn't it: more grip from new tyres means you can increase the load on the brakes! Tho the amount of energy is the same so it just means they can brake later and harder for less time but the total heat energy is the same. edit or What he probably means is they can corner faster so they don't have to dissipate so much . . .
Just goes to show that, like Scarbs and the others, if F1 journos could do F1 engineering they'd be doing itPlus they have deadlines. But it's a good read anyway and like him I can't wait for Spa
The stickier then tire, the higher the rolling resistance of course. But in the grand scheme of things, a very small difference between the compounds.digitalrurouni wrote: ↑06 Aug 2019, 05:24Dumb question but does super grippy tires generally get associated with higher rolling resistance? I was under the impression grip only comes into play when there's lateral and longitudinal forces ie brsking and acceleration loads being placed on the tire.
A fresh tire means you can brake harder, so brake temps will go up. It’s all about the amount of energy you take out of the car with brakes alone.zibby43 wrote: ↑06 Aug 2019, 05:19Regarding the brakes/tires point, was he referring to the fact that a fresh tire has more bite/grip? Better grip means better and more efficient braking performance. That has to help with managing the temps, as sliding around on older, slicker rubber often requires additional braking input.izzy wrote: ↑06 Aug 2019, 00:31Thanks. i generally have a lot of time for Matt Somerfield but there were a couple of nonsenses:zibby43 wrote: ↑05 Aug 2019, 22:23Awesome race analysis by SomersF1, including some pretty cool technical insights (regarding brake temperature management, etc.).
Furthermore, wouldn't the newer, stickier tires help with lifting and coasting (higher rolling resistance of the new rubber working in conjunction with the aero drag being generated when lifting off the throttle) - a strategy that Hamilton was doing frequently in order to help manage the brake temps?
yes this is why I said
that you accidentally missed off quotingedit or What he probably means is they can corner faster so they don't have to dissipate so much heat
Excellent! 18 is quite a good step, and done with secret molecules!! And 'vitaminize', such a perfect wordGPR -A wrote: ↑06 Aug 2019, 04:29Link -> Mercedes: 18 more horses from the new gasoline molecules
I think he just slightly lost the plot at this pointzibby43 wrote: ↑06 Aug 2019, 05:19
Does it not also mean that you corner faster so apply the brake for a shorter period? (also more moving air)Jolle wrote: ↑06 Aug 2019, 10:02A fresh tire means you can brake harder, so brake temps will go up. It’s all about the amount of energy you take out of the car with brakes alone.zibby43 wrote: ↑06 Aug 2019, 05:19Regarding the brakes/tires point, was he referring to the fact that a fresh tire has more bite/grip? Better grip means better and more efficient braking performance. That has to help with managing the temps, as sliding around on older, slicker rubber often requires additional braking input.izzy wrote: ↑06 Aug 2019, 00:31
If a car is slow, then you can break later before a turn. If it comes to the breaking zone with greater speed, then you break early and break harder before you take turn. No driver keeps breaking throughout a corner, it's before the corner entry.Big Tea wrote: ↑06 Aug 2019, 11:29Does it not also mean that you corner faster so apply the brake for a shorter period? (also more moving air)Jolle wrote: ↑06 Aug 2019, 10:02A fresh tire means you can brake harder, so brake temps will go up. It’s all about the amount of energy you take out of the car with brakes alone.zibby43 wrote: ↑06 Aug 2019, 05:19
New tires would enable higher cornering speeds so you would require less braking before the corner, but, corner exit would be higher so your speed would be higher entering the next corner thus possibly requiring more braking. Not sure what the trade off would be.Big Tea wrote: ↑06 Aug 2019, 11:29Does it not also mean that you corner faster so apply the brake for a shorter period? (also more moving air)Jolle wrote: ↑06 Aug 2019, 10:02A fresh tire means you can brake harder, so brake temps will go up. It’s all about the amount of energy you take out of the car with brakes alone.zibby43 wrote: ↑06 Aug 2019, 05:19
