Nice multi page speculation with no source whatsoever, apart from other forums.
Some people seem very sure of themselves.
The source that started the speculation is the AutoSport magazine. That's not to say the magazine is accurate either though.McG wrote:Nice multi page speculation with no source whatsoever, apart from other forums.
That was just a sketch to show what it "might" look like.mcjamweasel wrote:Scarbs posted this pic on twitter earlier:
http://yfrog.com/f/h7qg4stj/
I'd be amazed if that was declared legal, but then I'd also be pretty shocked if McLaren hadn't already cleared it with the FIA.
hollowBallistix wrote:It's infuriating that the FIA have banned Pyrosic for cost reasons, regardless of the material cost, if a manufacturer finds a clever way to use new materials and they come under the budget imposed on each team for the racing year then there should be no problem !!
It's probably been banned because some "other" teams have found out about the exhaust concept that McLaren are trying to run that relies on this material & have winged to the FIA about it !!!
I'm getting sick of this sport killing innovation !!!
Following your thinking.. why are we even hearing about this, and whys it affected their pace so recently?vall wrote:hollowBallistix wrote:It's infuriating that the FIA have banned Pyrosic for cost reasons, regardless of the material cost, if a manufacturer finds a clever way to use new materials and they come under the budget imposed on each team for the racing year then there should be no problem !!
I don't think so. It was long ago that the introduced (on cost grounds) the rule that the cars has to make of only certain materials. This excludes some expensive materials. It is not like FIA suddenly banned some material only because McLaren used it
murtoidf1 wrote:Following your thinking.. why are we even hearing about this, and whys it affected their pace so recently?vall wrote: I don't think so. It was long ago that the introduced (on cost grounds) the rule that the cars has to make of only certain materials. This excludes some expensive materials. It is not like FIA suddenly banned some material only because McLaren used it
Code: Select all
ARTICLE 15 : CAR CONSTRUCTION
15.1 Permitted materials :
15.1.1 The following is the list of permitted materials. These are the only materials permitted to be used in the
construction of the Formula One Car provided only that in all cases the material is available on a nonexclusive
basis and under normal commercial terms to all competitors.
1) Aluminium alloys.
2) Silicon carbide particulate reinforced aluminium alloy matrix composites.
3) Steel alloys.
4) Cobalt alloys.
5) Copper alloys containing ≤ 2.5% by weight of Beryllium.
6) Titanium alloys (but not for use in fasteners with <15mm diameter male thread).
7) Magnesium alloys.
8) Nickel based alloys containing 50% < Ni < 69%.
9) Tungsten alloy.
10) Thermoplastics : monolithic, particulate filled, short fibre reinforced.
11) Thermosets : monolithic, particulate filled, short fibre reinforced.
12) Carbon fibres manufactured from polyacrylonitrile (PAN) precursor. (*)
13) Carbon fibres manufactured from polyacrylonitrile (PAN) precursor which have :
- a tensile modulus ≤ 550GPa ;
- a density ≤ 1.92 g/cm3 ;
- unidirectional or planar reinforcement within their pre-impregnated form, not including three
dimensional weaves or stitched fabrics (but three dimensional preforms and fibre
reinforcement using Z-pinning technology are permitted) ;
- no carbon nanotubes incorporated within the fibre or its matrix ;
- a permitted matrix, not including a carbon matrix.
14) Aramid fibres.
15) Poly(p-phenylene benzobisoxazole) fibres (e.g. “Zylon”).
16) Polyethylene fibres.
17) Polypropylene fibres.
18) E and S Glass fibres.
19) Sandwich panel cores: Aluminium, Nomex, polymer foams, syntactic foams, balsa wood, carbon
foam.
20) The matrix system utilised in all pre-impregnated materials must be epoxy, cyanate ester, phenolic,
bismaleimide, polyurethane, polyester or polyimide based. (*)
21) The matrix system utilised in all pre-impregnated materials must be epoxy, cyanate ester or
bismaleimide based.
22) Monolithic ceramics.
[Materials marked (*) are permitted only for parts classified as either front, rear or side impact structures,
side intrusion panels or suspension members as regulated by Articles 15.4.3, 15.5.3, 15.4.6, 15.4.7 and
10.3 of the Technical Regulations respectively.]
Exceptions :
1) All electrical components (e.g. control boxes, wiring looms, sensors).
2) All seals & rubbers (e.g. rubber boots, o-rings, gaskets, any fluid seals, bump rubbers).
3) Fluids (e.g. water, oils).
4) Tyres.
5) Coatings and platings (e.g. DLC, nitriding, chroming).
6) Paint.
7) Adhesives.
8) Thermal insulation (e.g. felts, gold tape, heat shields).
9) All currently regulated materials (e.g. fuel bladder, headrest, extinguishant, padding, skid block).
10) Brake and clutch friction materials.
11) All parts of engines homologated according to Appendix 4 of the Sporting Regulations.
15.1.2 No parts of the car may be made from metallic materials which have a specific modulus of elasticity greater
than 40GPa / (g/cm3). Tests to establish conformity will be carried out in accordance with FIA Test
Procedure 03/02, a copy of which may be found in the Appendix to these regulations.
Code: Select all
Advanced glass-ceramic matrix composites with user-friendly processing
PyroSic
After 10 years of development, Pyromeral Systems has introduced an entirely new generation of materials that finally brings the advantages of composites to the world of high temperatures. With this technology, it is now possible to design and manufacture lightweight composite parts used at high temperatures that not only provide an excellent level of thermo-mechanical performance, but also remain easy and affordable to produce.
These new composite materials, marketed under the PyroSic® and PyroKarb™ names, are based on proprietary glass-ceramic matrix systems reinforced with silicon carbide or carbon fibers. Thanks to the use of advanced inorganic polymers, they are processed at low temperatures with the same techniques and tooling as those used for conventional carbon-fiber reinforced plastics (CFRP). Yet, they also offer a much improved resistance to heat and fire, as they retain good mechanical properties at temperatures for which CFRP cannot even be considered (typically, up to 1000°C/1800°F).
KeiKo403 wrote:All this exhaust talk got me looking at the regs: The regs state: "5.6 Exhaust systems: Engine exhaust systems may incorporate no more than two exits."
Pretty open really and no need to find a loophole.
So, my thoughts are, in the octopus/moose box, if McLaren mix exhaust gases (via 2 engine exits) with fresh air from some ducting (sidepods maybe) then the exhausts have effectively ended. In my car, the exhaust stops being an exhaust when the gases meet fresh air?
Correct me if I'm wrong! I'm not an expert. It's just an opinion as I like to think I'm pretty good when it comes to problem solving and thinking out of the box.
Thoughts please......
this was also my thought, but in this came the efficiency of the system will be small, no? I am by no means an expect in that thoughHolm86 wrote:KeiKo403 wrote:All this exhaust talk got me looking at the regs: The regs state: "5.6 Exhaust systems: Engine exhaust systems may incorporate no more than two exits."
I Believe that if the exhaust exits ends right before the entrance to this octopus box so there is a small clearing between the two then it would be legal? The exhausts does not need to go directly into the box. They can just blow into the entrance holes ...
