McLaren MP4-29 Mercedes
mikeerfol
68
Re: McLaren MP4-29 Mercedes
richard_leeds wrote:
mclaren_mircea wrote:According to Michael Schmidt (AMUS), Mclaren also had a new diffuser,and "close-fitting engine cowling" and leapfroged the other Mercedes customers, Force India and Williams (on Williams the modifications to the cooling system did not work as expected).
"McLaren at the moment the fastest Mercedes-customer
The best impression of the Mercedes clientele left McLaren. Apparently, the new diffuser and the close-fitting engine cowling have increases downforce at the rear."
http://www.auto-motor-und-sport.de/form ... 61471.html
Well that didn't work out did it? Ended up last of the 4 Merc powered teams.
Does anyone know if Button's fast FP1 used any experimental parts that were not used for the rest of the weekend? Or was it simply that he was on low fuel, perhaps with reduced ride height or unlimited fuel flow? In essence, was it a glory run or was it a precursor of things to come?
He didn't mention anything about experimental parts, just lower temperatures and I think he said somehting about fuel loads as well.
Xero
32
Yup, it was purely down to temperature. Was a lot cooler in FP1, and the McLaren seems to come alive in a very narrow window of temperature. The potential in this car is definitely there, they just need to understand why the car isn't working with this years tyre compounds. There's massive time to be found from small tweaks!
New aerodynamic part on top of side pod :D
Check AMuS
Jef Patat
Jef Patat
Didn't see what you saw, do you have a source?
Sorry - my mistake - looked again and it looks like a reflection. =D>
McLaren will change the nose like Lotus?
I read this here
https://translate.google.it/translate?s ... edit-text=
My first thought is that if it happens, it will be a pretty drastic change in airflow in that area and I'm not sure if the MP4-29 will cope with it. Lotus might have a car that could deal with a more "normal" nose (if we can call "normal" the d**k noses), but I have some doubts if the other way around is possible.
I could believe them going for a Merc type nose, but not the twin tusk.
adrianjordan
From what I gather, the rumour of the twin tusk nose for McLaren is based on nothing more than the fact that some Lotus aero guys moved to the team...
Favourite team: McLaren
adrianjordan wrote:From what I gather, the rumour of the twin tusk nose for McLaren is based on nothing more than the fact that some Lotus aero guys moved to the team...
I am italian,
This news was written by Giorgio Piola
Giorgio Piola occasionally discover something 'cause working in the paddock for years, he writes with great confidence that McLaren will have' the nose.
Although I am skeptical
SiLo
139
I can't see them moving to that nose, surely more than one team on the grid would be running it if it was so good?
Felipe Baby!
Jef Patat
Jef Patat
SiLo wrote:I can't see them moving to that nose, surely more than one team on the grid would be running it if it was so good?
I'm tempted to follow that reasoning. But then the same can be said of the butterlfies.
It's a -_-' reasoning. How many teams changed their nose design since the beginng of the season? and copied another design? how many team copied the best cars nose; the Merc, the RBR..?
Duke
I doubt we'll see different nose from any team until at least next season, if not the next, when the 'best' solution is found.
aral
aral
26
Who nose what will happen? Lets get back on topic, please!
