here is a linkDid McLaren had any cooling issues, except burnt bodywork? Can't find any, did I missed something?
(Facts, links, or confirmations please)
https://www.autosport.com/f1/news/13469 ... er-burning
So just some burnt bodywork, and quick fix?techman wrote: ↑18 Mar 2018, 21:11here is a linkDid McLaren had any cooling issues, except burnt bodywork? Can't find any, did I missed something?
i hope its a quick fix but did the quick fix work. we saw many holes created in the cover but did it stop any failures in the test.So just some burnt bodywork, and quick fix?
I respectfully want to ask, Can i know the source of your assumption?PlatinumZealot wrote: ↑18 Mar 2018, 19:49Its not all about how tight it looks from the outside.. Under the skin the engineers try to open up as big space as possible for air flow. The engine and gearbox anciliaries have to be squeezed tighter against the engine as a result. Only clever designs can keep the cooling and servicing of these areas from getting too difficult. Apparently McLaren did the opposite of Toro Rosso and went in too aggressivley with their first time with Renault. After experiencing the power of influencing engine packaging details that comes with being a works team, McLaren should have known better becoming engine customers. McLaren took a risk and it didn't work. Renault arent willing to spend any resources on modifying the engine for them and it looks like McLaren has to make custom engine ancilliary parts to get around the problems.
A couple more problems like that and Boullier will be doing some gardening.I don't think it's as complex as that. They had 5 breakdowns, one was a loose wheelnut, two were battery issues, one was a turbo problem, the last was a hydraulic leak, and a broken exhaust.
They also admitted that they could have done a better job preparing the car for the test. The issues aren't that serious.
seems like the only people talking about "size zero" these days are mclaren haters. basically every team has size zero now. i wonder if ron dennis hadnt coined the term 4 years ago, would all these people even bring up the size factor as hondas excuse for not building a good power unit.Andres125sx wrote: ↑18 Mar 2018, 12:04So.... you´re bashing McLaren because of size zero philosophy, and two lines after you bash McLaren because even STR packaging is slimmer??carisi2k wrote: ↑18 Mar 2018, 00:12Surely you guys can't be blaming the Renault engine for Mclaren's issues. No hiding this year for Mclaren when they can be directly compared to Red Bull. If the Renault engine is reliable in the Renault and Red Bull then the size zero philosophy will be shown to be faulty. In any case when you have a look in the car comparison thread you can see that while the Mclaren is easily the shortest car on the grid. Many of the other cars and especially the RB14's sidepods are much narrower then the MCL33's. Even the STR13's are slimmer and more aerodynamic then the MCL33. Surely it is time for Mclaren to refine it's philosophy in regards to chassis design.
viewtopic.php?f=12&t=27033&p=749092#p749092
I know haters gonna hate, but this is too absurd man
You could install 2 PU's in the rear of the STR by the looks of it so you'd have to ask questions if they suffered from issues with cooling.fellowhoodlums wrote: ↑19 Mar 2018, 00:02I am sure McLaren has cooling issues too with the time it takes to get the engine installed. That and the 5 breakdowns mentioned are to be expected.
Torro Rosso had similar issues with the Honda install.................
You don't remember last year they had to shift earily cause of vibrations?Monster Hesh wrote: ↑17 Mar 2018, 17:19From what could be heard from the tweets that McLaren made of the MCL33 setting off, it never sounded smooth or controlled. They had alot of learning and map implementing of the Renault engine, especially wet mapping.
Wonder if the Honda engine enabled them to have supreme driveability out of corners and they they will really miss that aspect. Or if during winter testing they got enough data to gain the control of the Renault engine out of corners.
Wasn't vibration caused by geabrox and engine resonance?diffuser wrote: ↑19 Mar 2018, 02:48You don't remember last year they had to shift earily cause of vibrations?Monster Hesh wrote: ↑17 Mar 2018, 17:19From what could be heard from the tweets that McLaren made of the MCL33 setting off, it never sounded smooth or controlled. They had alot of learning and map implementing of the Renault engine, especially wet mapping.
Don't think they got it resolved till late in the summer?
