2025 Scuderia Ferrari F1 Team
venkyhere
Re: 2025 Scuderia Ferrari F1 Team
Farnborough wrote:
26 Mar 2025, 23:44
This SF 25 conundrum appears to be around just how narrow that floor to ground dimension is. Notably effective in Aus practice, again China sprint Q and race, but they can't keep it there a whole race without plank risk.
Perhaps this discussion should be over in the car thread :D
Right, we have already raised (not literally :D ) this suspicion : https://www.f1technical.net/forum/viewt ... 6#p1274916
Farnborough
Farnborough
124
venkyhere wrote:
27 Mar 2025, 07:28
Farnborough wrote:
26 Mar 2025, 23:44
I can see what you meant there (I read it when posted) but don't feel its related specifically to tyre contact patch as you noted.
It seems generally accepted though that a floor "landscape" or whatever we would call it, has a profound effect on whether the load is delivered in narrow spiked peak or broader more malleable envelope.
The peak type COULD give ultimate load, but create a very significant problem for the team's suspension experts in exactly how they can get it there, further to hold in that zone.
The opposite, with broader responses in floor, may ultimately mask suspension absolute performance by simply making less concise demands. This such that a competent suspension performance could be judged as very good or exceptionally poor (the same system) depending on which floor it's given to work with.
I suppose that's saying, if they don't fully understand the floor, then almost impossible to match that with mitigation in suspension, whatever the skill level they have invested in tbat department.
Edit to add:- this car does appear to possess good performance, at that lowest level. That's clear in evidence we've seen so far, particularly in China SQ & S as it easily held sway throughout. Full race pace, in the two so far, no not for that setup snd duration.
venkyhere
Farnborough wrote:
27 Mar 2025, 09:27
venkyhere wrote:
27 Mar 2025, 07:28
Farnborough wrote:
26 Mar 2025, 23:44
Perhaps I should have elaborated my post in the car thread, better.
While we both are in agreement that there seems to be a mis-marriage between the floor and the rear suspension, there seems to be disconnect in our perception of the tyre contact patch.
From my view, the softer suspension need is not related to 'load' pressing the wheel down, but rather from the camber change on the outer wheel from roll and creation of a 'bigger' contact patch, when car is under yaw in a corner, inorder to help traction AND tyre durability.
Slightly softer vertical and roll stiffness (without sacrificing pitch and heave stiffness), diminishes the negative camber and creates a nice 'pulp' of outer rear tyre, that allows earlier application of throttle and good traction from a 'bigger' contact patch. We can see this behaviour from the oboards of chasing cars when Ferrari is in front, the traction from exit of corners is very good (I suspect McLaren too has the same 'suppleness' in their rear suspension - not mad stiffness, granting them the same traction advantage).
Such 'adding softness' to the rear will inadvertently need to allow for greater vertical movement of the floor (under yaw, while the car is rolling), which in turn will impose a lower limit on how little the static ride height the car can have, otherwise the skidplate/plank will rub more than allowed.
The Q then becomes what kind of 'demand' the floor should make on the suspension - more leaning towards peaky and asking a "lot" of compression or more leaning towards 'spread' and not ask the limit of spring compression ? That will define the 'base setting' for the entire season with this car, unless some 'upgrades' change the aero or suspension maps. This being a chicken-egg problem (floor defines suspension or suspension defines floor), my wild guess is that Ferrari got their tradeoff equations wrong somewhere along the way and found out the hard way in the dry and with full tank of fuel, not in China, but in Bahrain itself. Perhaps Hamilton's 'setup' within the window of 'allowable variations' around their 'base setting' exposed it (remember the aborted long run on the final day of testing) and LeClerc's 'setup' didn't. They must have found a way to 'deal with it' by making changes between testing and the first race. However, in China, Pirelli torpedoed them by pumping up the tyre pressure, and Hamilton's car again 'showed up' the plank problem, while LeClerc's didn't.
Either way, this is classic "F1" - they solved the problem (porpoising) when there is no 'yaw' and the floor is working at it's peak at top speed in a straight line (perhaps with heave stiffness, floor peak DF peelback etc) ; while this season it has come back again under yaw in the corners, when the 'final setup' takes it away from the base setting too much.
This is what leads me to conjecture - compared to the rest of the big teams, Ferrari might have slightly shallower tunnels, even if they aren't aiming for a peaky floor (as we know, contraction ratio from floor entry to venturi and expansion ratio from venturi to diffuser exit defines the peak) and that has come back to bite their a&& in the form of static-height-sensitivity-of-downforce, in situ with their 'base suspension stiffness' defined by geometry/materials etc.
ScuderiaLeo
From Vasseur:
"My job is to analyze the positives and negatives of every situation in order to progress. Every race weekend has both good and bad aspects, and this time, we experienced both extremes. Unfortunately, what people remember most is usually the last race or event. So we returned with some frustration because we felt we had made a step forward compared to Australia. This didn’t translate into points due to the disqualifications, but I believe we were on the right path, with many positives: Lewis’ pole position and victory in the Sprint race, and Charles' strong performance on Sunday."
"We achieved part of our goal: we no longer need to answer questions about our first pole or first win. Among the three races so far, this was one of our strongest performances. Finishing seven seconds ahead of second place in a race that lasts only a third of a Grand Prix answers some of the doubts and questions."
[...] After a promising start to the weekend, Ferrari had to face the disaster of a double disqualification, though for different reasons. Much discussion centered on Leclerc’s one-stop strategy, which led to higher tire wear and ultimately left his car underweight in post-race scrutineering. Vasseur added an additional detail, recalling a similar issue in Melbourne:
"That wasn’t the only problem. The tires were just part of the explanation… We also lost a liter of water due to Charles’ leaking drink reservoir. Disqualification for weight is always the sum of many small factors."
For Hamilton, excessive wear on the skid block under the car—similar to the issue that led to Leclerc’s disqualification in the 2023 U.S. GP—resulted in his DSQ. Coincidentally, Hamilton’s Mercedes had also been disqualified in that same race, once again linking the two drivers’ fates. Vasseur admitted:
"Yes, we were probably too aggressive. This disappointment shows that we are chasing perfection—and sometimes, we push too far."
"Disqualifications happen sometimes. It’s important to distinguish between a disqualification due to risk-taking and one due to misconduct. In F1, the goal is to push every parameter to its absolute limit—down to the last gram of weight, the last tenth of a millimeter on the skid block, the last millimeter of wing flex. The more intense the competition, the closer we get to those limits, and the more risks we take."
Is this the second race in a row where Charles' drink leaked? Why is he always having drink issues? Are his mechanics that bad? Why is this considered a factor in weighing the car? I have so many questions...
kptaylor
kptaylor
The car has drains, so any leaking drink will drain out, thereby reducing the car's overall weight. If he doesn't typically drink that much I wonder why they'd be overfilling his drinks container...
ScuderiaLeo
Leclerc's water problems from the past year:
  • Miami 2024: No drink
  • Hungary 2024: No drink
  • Mexico 2024: Water leaking
  • Qatar 2024: No drink
  • Australia 2025: Water leaking
  • China 2025: Water leaking (?)
I don't think Sainz/Hamilton's side of the garage has had this many problems with this one specific part. Correct me if I'm wrong. I just don't understand how they can mess up the same thing over and over?
catent
Many of the mechanics on Leclerc’s side of the garage were formerly mechanics on Vettel’s car, no? And if I recall correctly, some within the team resented Leclerc for challenging Seb, who they adored.
Given the frequent and consistent issues with Leclerc’s car, going back multiple years now, be it odd tire warmup issues, leaking drink, parts improperly installed, etc, I’m highly suspicious of someone (or more than one person) sabotaging Leclerc’s car. Sounds a bit crazy, yeah, but no less crazy than the reoccurring issues Leclerc has had with his car over the years.
Need to clean house on that side of the garage.
ScuderiaLeo
catent wrote:
27 Mar 2025, 23:32
"Never attribute to malice that which is adequately explained by stupidity" applies to Formula 1 too.
Seanspeed
Seanspeed
catent wrote:
27 Mar 2025, 23:32
Yes, suggesting that Ferrari have a garage full of people that are sabotaging their own lead driver is indeed crazy, in probably the most literal sense possible.
This feels like one of those situations where you have an intrusive thought in your head, but you keep it yourself and realize it's ridiculous, not write it down on the internet and hit 'Submit' as a serious claim.
ScuderiaLeo
I wasn't trying to insinuate sabotage LOL... just that his garage isn't very good.
deadhead
68
I don’t know about conspiracies, etc. but his water situation is bizarre to be honest … been having issues for years now hah
catent
Seanspeed wrote:
28 Mar 2025, 01:53
catent wrote:
27 Mar 2025, 23:32
I think I’d say the same - keep it to yourself - about your post ridiculing me for sharing such a thought.
The “intrusive thoughts” comment seems more like a form of self-reporting than anything else. Someone having a far-fetched, conspiratorial idea related to Formula 1 by no means indicates one is actively fighting intrusive thoughts and they just can’t manage to keep them internalized. It’s far-out, sure, but just a thought (one I provided a rationale for, and ultimately acknowledge as unlikely).
I’m not the only voice who has suggested cleaning house on Leclerc’s side of the garage, I recall Vanja blowing that horn in recent seasons, too (for whatever that’s worth). And whether it’s a matter of malice or incompetence, there is no argument that the frequent and consistent issues Leclerc has had with his racecar over the past several seasons occur at a far greater rate than they do to the other Ferrari, let alone any other driver on the grid. That seems to suggest that reevaluating his mechanics may be a wise idea (again, even if we assume it’s a matter of incompetence, rather than sabotage).
240
The team need to change the drink bottle supplier. The connections could be poorly designed.
I dont recall where the bottle is, but the malfunction on one car could have to do with Charle's molded seat. Can be a simple as that.
Maybe under high G's the bottle gets squeezed and the hose connection fails or unscrews.
ScuderiaLeo
ringo wrote:
28 Mar 2025, 07:27
This has been happening for years now, as deadhead said, if it had something to do with the design of the car or its parts, surely they would've changed it by now, right?
I still think it's just incompetency on the part of his main mechanics.
In other news, from Giuliana:
[...] The aerodynamics department, led by Tondi, showed last season that despite some technical errors, the team had found the right development path. The SF-25 has gained aerodynamic downforce, but mechanical platform limitations prevent it from being used effectively. Major changes to the suspension-gearbox assembly resulted in a problematic rear end, even though the design aimed to expand the setup window, optimize weight distribution, and strike a better balance in the diffuser keel's volume. None of that has materialized on track yet.
Loic Serra is guiding the team through “band-aid” solutions, working within the FIA’s strict limitations on in-season mechanical modifications—changes are only allowed for reliability issues. With 2026 approaching, recovery plans must be carefully weighed, especially in terms of budget rather than timeframes.
We had already reported that Maranello explored a more aggressive aero-mechanical front-end concept for the SF-25, adopting a suspension closer in design to McLaren’s. The switch to a front pull-rod suspension, decided last May, was only the first step in a broader analysis of the front-end layout during chassis and mechanical group development. McLaren took it even further, redistributing suspension kinematics and repositioning key components for aerodynamic benefits. This reportedly added about 3 kg to the front suspension, a calculated structural risk.
Extreme anti-dive geometry was another concept Ferrari studied in recent months but ultimately scrapped, seeing more downsides than advantages.
.poz
.poz
51
ScuderiaLeo wrote:
28 Mar 2025, 14:56
i'm afraid there are unexpected flex/torsion on the gearbox
