nzjrs
Wow, thanks a lot tok-tokkie. A lot of great information in that video translation.
etusch wrote:
20 Jan 2022, 14:11
Thank you @tok-tokkie
Anyone has any knowledge or gossip about Honda's 2022 Pu project ?
I'd say something, but I'm bored of hearing the same lame chants regarding the source. It's better than the last one, or they wouldn't show it.
lio007
320
godlameroso wrote:
20 Jan 2022, 21:01
etusch wrote:
20 Jan 2022, 14:11
But I'm very interested. I'd really appreciate it if you could share it with us!
etusch
131
godlameroso wrote:
20 Jan 2022, 21:01
etusch wrote:
20 Jan 2022, 14:11
I like your comments. It's up to you to decide but I would prefer you don't take care them.
f1motta
f1motta
64
As I mentioned in "Honda engine development secrets" video young enginers from Sakura have been given a task related to the Verstappen's poor starts. See how they solved this problem.
Zynerji
111
f1motta wrote:
21 Jan 2022, 23:15
So it's an ultra-long intake runner? 🤣🤣 can we call it the Elephant Trunk VLIM?
f1motta
f1motta
64
Yes, we can!
mzso
mzso
65
f1motta wrote:
21 Jan 2022, 23:15
Some of the subtitles are a tad questionable. Like "If it's a problem this time, it's quite low for the area of tone deafness", "As an artist, the engine speed changes when the clutch is engaged".
Also "5 Guess world of juicy ass" was for a part that's actually in English.
So some parts are incomprehensible. Is "champer" actually word, for anything related to an engine? Ir is it just chamber messed up?
NL_Fer
NL_Fer
82
Zynerji wrote:
22 Jan 2022, 00:21
f1motta wrote:
21 Jan 2022, 23:15
The interesting part was the explanation that the bad starts were caused by unstable combustion at lower RPMS. After releasing the clutch, the drop in RPM makes combustion more unstable, causes a lower than expected torque output. Which results in bigger drop of RPM than expected and the anti-stall puts the gearbox in neutral.
The step for Honda to ask Redbull to redesign the intake runner must have been big. But the result is great.
etusch
131
I think it is just a wrong writing but I will correct anyway. It disangage clutch not put gb in neutral
anthonyfa18
anthonyfa18
27
f1motta wrote:
21 Jan 2022, 23:15
As I am in Canada is there a way I can download the full video report of the hound f1 pu I am even willing to pay for download
Rodak
Rodak
37
... causes a lower than expected torque output. Which results in bigger drop of RPM than expected and the anti-stall puts the gearbox in neutral.
Actually I think it activates the clutch to prevent stalling.
NL_Fer
NL_Fer
82
Rodak wrote:
23 Jan 2022, 00:00
etusch wrote:
22 Jan 2022, 19:33
It used to switch to neutral in older days, but maybe it uses the clutch now. I don’t know, the result is anti-stall. Anti-stall mate !! :oops:
saviour stivala
saviour stivala
I believe that the system still also selects nautral as well as kick-in reves/adds throttle. (ECU/TCU will not allow engine rev's to drop bellow idle set speed) ''If transmission is in gear and the engine begins to stall the TCU will engage the clutch to break the engine free of tranmission, at the same time it also gives the engine extra 'gas'/more throttle''. some say that present power units reaches critical stage of stalling (RPM) at 2900 RPM. The 2.4l V8's critical stage RPM was much higher, the FERRARI 056 V8 critical stall stage RPM was said to be 4400 RPM.
Looks like the VLIM trumpets extends to mate and seal with the "elephant trunk" to create a really long runner to stabilize the air-flow at very low Rpms. I belive the elephant trunk has a step at the entrace of it into a larger diameter charge pipe.
