Paddy Lowe said on launch day the wheelbase is the exact same figure as the MP4-26Mr.S wrote:How can you say that?? Mclaren's wheelbase is a bit shorter. Atleast it seems to be from the naked eye.
Robbobnob wrote:the low nose in the brawn wasn't for aero benefit, rather it enabled them to place ballast low down at the front of the car for optimal weight distribution. with mandated weight distribution continued for 2012 i doubt we will see this feature repeated.
Will indeed be very interesting to see which nose concept Mercedes go for. Every team bar Mclaren have gone for a high, stepped nose. I know that a high nose allows for more air to go to travel to underside of the car and eventually the diffuser. But what are the benefits of having a low nose? Lower COG? More downforce produced at the front as opposed to the rear?Coefficient wrote:Robbobnob wrote:the low nose in the brawn wasn't for aero benefit, rather it enabled them to place ballast low down at the front of the car for optimal weight distribution. with mandated weight distribution continued for 2012 i doubt we will see this feature repeated.
It was actually for aero benefit too. Having the nose closer to the mandated central section of the wing has the effect of fooling the non aero profiled central section of the front wing into thinking it is indeed a wing by creating an area of high pressure between the front wing pylons thus yielding small downforce gain. Brawn had mastered this philisophy after first introducing it on the Ferarri in 2001 and refining it ever since.
After 2009 it was became irrelevant as the RB idea proved the way to go under the new regs but those regs have now changed and Mclaren clearly think they can make the low nose work again. Maybe Brawn will concur?
You have gotta be kidding me. Weren't they supposed to sell the team this year according to you???xpensive wrote:The W03 will without a doubt be something sensational.
As someone has previously mentioned, this is the Lewis Hamilton of teams. There is always someone to fling mud around every corner, yet someone always defends them.N12ck wrote:How come for every post on the other car forums you get like 2 or 3 more on this one It happens every year
So the lineup so far for mercedes trickery is:
FW F-duct
Mecury Suspension,
High nose
I wonder maybe if they will go for a low nose after years of experience with low noses (last year was high,,, I know) , but that was 1 year, hmmm
