Mclaren MP4-30 Honda
Goran2812
Goran2812
27
Re: Mclaren MP4-30 Honda
michaelclarke wrote:
mikeerfol wrote:Now that's weird, red flow-viz paint!
https://scontent-fra.xx.fbcdn.net/hphot ... e=55C6556C
Can anyone pretty please find this in higher resolution?
Reminds me of the Carmagedon game... haha, looks EPIC! =D> =D> =D>
Visit my photo page! -> http://www.gorankphoto.com/formula1
This looks even better:
rapha-78
rapha-78
In your opinion what is the impact of having a darker paint ? obviously it means less weight because a darker paint has a lower density but on the other hand it could be hotter and represent a problem of temperature. Probably also an aerodynamic issue because if it is hotter the density of the air and the flow is lower so less downforce. What do you think guys ?
To me the Barge-board & the Airflow Conditioner bottom (where attaching) looks different:
What do you guys think ?
matt_s
matt_s
rapha-78 wrote:What do you think guys ?
With all the red floviz, I think it looks like the driver has gone straight through the box at speed and taken out most of his pit crew.
FrukostScones
is it Ron's blood from bloodletting?
or the blood of his enemies?
"I ain't with the FIFA, I'm in Tokyo." LH
ajprice
ajprice
21
FrukostScones wrote:is it Ron's blood from bloodletting?
The blood of anyone who said the word orange to his face.
Cause of the change in liveries, it hard to see the shape differences from the previous race.
If they're running flow vis just about from front to back, there must be many changes we haven noticed ?
f1rules
f1rules
635
i cant spot anything other then the simple round rearsuspension part, but the pics suggest that they back to back tested two different frontwings in fp1, there are pics of a clean one without any paint and one which has been wiped clean, but seems its only minor changes to the outwas sections of the elements, thats exactly where they added flowvis at the last gp also, other then that, i cant spot anything
Jef Patat
Jef Patat
66
rapha-78 wrote:In your opinion what is the impact of having a darker paint ? obviously it means less weight because a darker paint has a lower density but on the other hand it could be hotter and represent a problem of temperature. Probably also an aerodynamic issue because if it is hotter the density of the air and the flow is lower so less downforce. What do you think guys ?
I think the effect of colour on density is marginal. I don't even think you are correct. If I remember correctly to create black with substractive colour mixing you need more pigment and thus a thicker paint layer.
Aerodynamics impacts will be marginal. The ambient air temperature of air 'hitting' the car remains the same.
acosmichippo
acosmichippo
I think since there's carbon fiber underneath, darker paint colors will require fewer primer coats. No it isn't less "dense", just less paint mass overall. But I'm no paint expert.
mclaren_mircea
mclaren_mircea
It was said on German Sky that Honda brought 60HP to this race.
mclaren_mircea
mclaren_mircea
Acordding to AMUS, Honda found some power without using tokens, but on the chassis side, the modifications at the wings did not worked as expected.
Source: http://www.auto-motor-und-sport.de/form ... 17301.html
FW17
185
Not bad. 3rd quickest team already
He drove over them and forgot to wash off the blood?
