Image from the f1 rule book:
The FIA scrutineering bay (you can see the parts on the right side of the image that fit the holes):
They're closed holes. I don't understand how they can interact with the airflow, or what are you assuming...jagunx51 wrote:ohhh..... is it possible/allowed to make specific shape of the hole, thus could generate desired airflow ?RicME85 wrote:They are on all cars, they are mandated.
Fixing points + FIA measuring points iirc
imo, its a big hole .... and considering there is only small gap between underfloor and the track, 7 holes could make distraction to airflow ... if the function are just to be fitted with the scrutineering bay, why teams not seal them with some kind of tape (or else) for smoother airflowDream Theater wrote:They're closed holes. I don't understand how they can interact with the airflow, or what are you assuming...jagunx51 wrote:ohhh..... is it possible/allowed to make specific shape of the hole, thus could generate desired airflow ?RicME85 wrote:They are on all cars, they are mandated.
They don't do that, because the tape (or something else) would be considered "bodywork" by the FIA, and then the team would have bodywork visible from under the car that's not on one of the reference or step planes. That would make their car illegal.jagunx51 wrote:imo, its a big hole .... and considering there is only small gap between underfloor and the track, 7 holes could make distraction to airflow ... if the function are just to be fitted with the scrutineering bay, why teams not seal them with some kind of tape (or else) for smoother airflow![]()
http://i.imgur.com/fBqRohV.jpg
It's not really a big deal, because the diffuser is fed by air flow along the sides of the plank, not directly under it.jagunx51 wrote:imo, its a big hole .... and considering there is only small gap between underfloor and the track, 7 holes could make distraction to airflow ... if the function are just to be fitted with the scrutineering bay, why teams not seal them with some kind of tape (or else) for smoother airflow![]()
My recollection is that those wooden planks were added for 2 reasons: to reduce downforce and to make the chassis bottom/diffuser downforce much less dependent on variations in the ride height of the car.jagunx51 wrote:looks like an uneven plank ..... what are they for ? i'm just wondering how they affect the airflow towards diffuser....
That's another rule they should change. They should run on regular pump fuel.ecapox wrote:I have looked around at my usual sources and see nothing about the Shell fuel. Not to say that it is going to be published. I'd try to keep it hush hushif possible.
Standing starts after a safety car?Powershift wrote:I guess this goes here
Formula 1 teams in push to make cars more visually spectacular
http://www.autosport.com/news/report.php/id/113621
Sounds great to me. The current rolling start gives an obscene advantage to the leader. A standing start would also make it much easier to sort out the mess with back markers needing to join the back of the procession, as the leaders would no longer be moving.mikeerfol wrote:Standing starts after a safety car?Powershift wrote:I guess this goes here
http://www.autosport.com/news/report.php/id/113621![]()
I dunno. A standing start means that the cars would have to stop. Depending on how long they are held for presumably that would mean a 'restart' as in when a race is red flagged, so pit crews on the track etc, tire warmers on etc etc. Whilst I think the current system and especially the time wasted with backmarkers unlapping themselves (wouldn't it be easier for them to pull over and let the crocodile pass them?) needs improving, at least it's fairly quick. A standing start could mean a 15 minute delay which I really wouldn't want to see. If it doesn't mean teams on the track then cold tires/stalls are just going to cause carnage at the restart.beelsebob wrote:Sounds great to me. The current rolling start gives an obscene advantage to the leader. A standing start would also make it much easier to sort out the mess with back markers needing to join the back of the procession, as the leaders would no longer be moving.mikeerfol wrote:Standing starts after a safety car?Powershift wrote:I guess this goes here
The same advantage the leader had lost with the safety car?beelsebob wrote:Sounds great to me. The current rolling start gives an obscene advantage to the leader.
