It's a car that's been developed for nearly 2 years now, the odds are definitely in favour of a 2011 go-around.FrukostScones wrote:not really, but I hope i m wrong.Juzh wrote:That's a little bit premature to predict now, is it?FrukostScones wrote:Interesting how low RB can run their FW. Game over, RB9 is here.
stefan_ wrote:Jerez - Day 4 (08.02.2013)
avatar wrote:Is it just me or is the left side of the f/w closer to the ground in this shot?
It doesn't look like the car's jacked up anywhere - any ideas?
look at the front wing,is almost touching the flooravatar wrote:Is it just me or is the left side of the f/w closer to the ground in this shot?
The car is running alot of rake, then that would probably the reason why it so low. I have to wonder though, with a full tank and with alot of downforce on it, if that FW isn't going to be damaged by scraping the ground, even with stiff suspension.wesley123 wrote:Nope, measurements are taken from the reference plane, and never from the ground, since that is variable.
More fuel in the back --> more lift in front? Isnt that how its supposed to be?turbof1 wrote:The car is running alot of rake, then that would probably the reason why it so low. I have to wonder though, with a full tank and with alot of downforce on it, if that FW isn't going to be damaged by scraping the ground, even with stiff suspension.wesley123 wrote:Nope, measurements are taken from the reference plane, and never from the ground, since that is variable.
Good point. Is the height of the front wing measured when the fuel tank is full? That would lift the front, but as fuel was used, the rear would rise and the front wing would get closer to the ground. Remember too, that as the fuel load lightened, the car would also get faster, so a lower front wing would then be more of an advantage.Juzh wrote:More fuel in the back --> more lift in front? Isnt that how its supposed to be?turbof1 wrote:The car is running alot of rake, then that would probably the reason why it so low. I have to wonder though, with a full tank and with alot of downforce on it, if that FW isn't going to be damaged by scraping the ground, even with stiff suspension.wesley123 wrote:Nope, measurements are taken from the reference plane, and never from the ground, since that is variable.
