I can give you a good solution to aquaplaning.
Slow down.
To be fair, in lower racing series (I'm thinking karting), the response to marshals on track is to have all cars immediately stop in their current place. That doesn't work for F1 because of the cooling requirements, but I wonder if it could work given enough notice for the engineers.Lycoming wrote:By that logic, any time a car needs to be removed from the track you would have to red flag the race.
Economic factors will be a major factor for existing pavement, but a lot of circuits have laid new paving over run off areas recently. New circuits have also been built as well in Austin and Sochi. So people do put down new paving when the need/have to. I think the dominant issue in F1 is "doh, that never occurred to us".Ciro Pabón wrote:The main reasons to avoid porous asphalt use are, as mentioned:
• Statu quo
• Economic factors.
It definitely would work if the power train was designed to include that requirement.Moose wrote:To be fair, in lower racing series (I'm thinking karting), the response to marshals on track is to have all cars immediately stop in their current place. That doesn't work for F1 because of the cooling requirements, but I wonder if it could work given enough notice for the engineers.Lycoming wrote:By that logic, any time a car needs to be removed from the track you would have to red flag the race.
Richard wrote:Andres - I give up.
So you two basically say that Alex Wurz and Pedro De la Rosa statements about bumps increasing year by year on braking zones are just a product of their imaginationCiro Pabón wrote: [...]
Probably my fail as I can´t explain it properly, even when my example of a gravel road resisting a truck but not a hard braking from a bike or a car was very enlightening I think, but it´s been enough for meRichard P. Feynman wrote:It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
I'm sure Alex and Pedro are correct in saying that the asphalt design/construction/maintenance at that point needs to be improved.Andres125sx wrote:So you two basically say that Alex Wurz and Pedro De la Rosa statements about bumps increasing year by year on braking zones are just a product of their imagination.
As if experiments never got it wrong... I've got papers discussing that sort of thing. Eventually, when samples and techniques are pushed to the extreme, the risk of contamination, or misinterpretation or misunderstanding increases. And to put an example:Andres125sx wrote:Probably my fail as I can´t explain it properly, even when my example of a gravel road resisting a truck but not a hard braking from a bike or a car was very enlightening I think, but it´s been enough for meRichard P. Feynman wrote:It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Have a good day
you can't be serious, of course the worlds best drivers in some of the most extremely cars can drive at pitlane speed when there is people or equipment on the track. If they couldn't how could they ever pit where there is hundreds of people?SweetApex wrote:It's simple, it doesn't matter when yellow flags are out or if a safety car is present, marshals and tractors should not be present when cars on the track at pit-lane speed or obviously racing speed.
If a brake failure occurs during a safety car period and there is no response from driver input of the brake pedal. They will go straight off into a section containing marshals and tractors. Even at 50km/h that is still a significant crash.
Under double waved yellow situations (wet/dry) if a wheel falls off or a car spins off the track it doesn't matter how safe you are, things happen.
Now I have just outlined the simple problem here. It's up to a team of investigators allocated by the FIA to come up with a solution to this problem. It's not easy, but as long as it's safe that's all that matters. One life lost is one too many.
Whiting said the FIA would also consider putting 'skirts' around recovery vehicles to ensure it was impossible for cars to go beneath them.Charlie Whiting wrote: One of the most important things to learn here is that it is probably better to take the decision to slow down away from the drivers, to have a system where it is clearer to everyone how much we think drivers should slow down.
We have a meeting with the teams on Saturday to discuss a way of imposing a speed limit. It would have the same effect as a safety car because if you slowed everyone down to the same pace they would hold position.
The fact that De La Rosa and Wurz complain about bumps in braking zones doesn't mean they are caused by braking, even if they say so. They're drivers, not pavement builders.Andres125sx wrote:So you two basically say that Alex Wurz and Pedro De la Rosa statements about bumps increasing year by year on braking zones are just a product of their imagination
And that is because you don´t know any technical explanation for that to happen...
It's not my intention to discourage contributions to threads, I apologize if the facepalm picture I posted is interpreted as mockery of your posts, Andrés. Won't happen again, it's not what I meant.Andres125sx wrote: ... Ok, this is my last contribution to this discussion
But the good thing is people won´t be hitting tow trucks at 100km/h if they go off at 60km/h or less.autogyro wrote:Many times cars have spun and crashed on wet warm up laps because they were going too slow to generate high down force.
