Infiniti Red Bull Racing 2015
Jolle
Jolle
133
Re: Infiniti Red Bull Racing 2015
djos wrote:I bet Infiniti are on RBR's side on this as Renault is making them look bad by association!
Renault owns 43,4% of Nissan/Infiniti, so I think not...
djos
113
Infiniti is the naming rights sponsor of RBR, so who owns what is irrelevant!
"In downforce we trust"
Richard
Richard
FoxHound wrote:Where in this hypothesis does openly berating Renault fit? Carlos Ghosn(The Renault boz-boz) is having kittens over this, I can assure it.
Further, why would Abiteboul openly wade into this and call Red Bull out over the demands they made?
Because both parties are annoyed that they've ended up in a situation where they've put untested parts on a race car. They took a gamble hoping it would get them out their predicament. It didn't so now they're grumbling about why they were in that predicament in the first place and pointing the finger at the other for devising a failed plan to get out.
I imagine that both Renault and RB are correct when viewed from their own perspective. I also imagine than an outsider with full knowledge of the situation would probably say both of them were at fault. After all they're meant to act as a team and should be jointly involved in decision making, hence jointly responsible when that breaks down.
Not trying to create moderator infighting here, but I partly disagree :P.
Renault and RBR are still seperate identities. Yes, you are correct to state they should work together as a team.
Fact is they aren't: Red Bull does not want share certain details about its chassis/packaging and Renault does not want to share certain details about its power unit. There is and always will be a certain level of distrust, and the rumors of Renault wanting to return as a works team in F1 have certainly not helped in this regard.
There will be an exchange of information in an attempt to lead to the correct decisions, but since both are seperate identities, it's also best each makes certain decisions on their own.
You were correct stating earlier that the performance updates would have costs tokens if not introduced before Melbourne. However, they will have been aware of the risk that if the updates do not work, that they are wasting very valuable power unit components. Not only did it cause ricciardo, and perhaps verstappen too, to loose an ICE, the ICE he currently has been put in is the same as the one that broke down. So they are 1 ICE down and the same issue is still there.
Now it did not cost tokens; now it'll costs both Renault and RBR a very hazard of a season. If they put in a third ICE with updated reliability, they only have one regulatory allocation left to put on the tokens allocated to the ICE. This will certainly lead to multiple ICE's being used beyond the regulatory 4, resulting in quite a few penalties. If they wait with the reliability updates until the development tokens are ready to be applied, then they need to keep running the detuned engine until they are ready, most likely Spain. Either way, their season has been destroyed: either by running a detuned state until they reach the strategic point of token introduction, or being penalized multiple times at the end of the season. The reason? A hasty last minute introduction of untested parts.
As long as they don't put in the reliability updates, which require yet another new allocation of components, components run a very high risk of breaking down or need to be run in a detuned state.
That's a risk that Renault knew would be there. RBR are as ignorant as critical customer can be, but renault should have known that was not the best decision.
FoxHound
55
In no way is a public spat the way get equalisation or progress.
As I mentioned before, after qualifying in Melbourne there was a very heated exchange between Taffin and Horner/Marko, Adam Cooper reported.
This is very real and not a charade.
Besides, other than bad publicity think of the consequences.
Should Red Bull get what they want, and then continue their domination of 2010-13, what will people say?
Bad losers only started winning because they complained?
Its mindless.
JET set
HairyOne
HairyOne
Juzh wrote:
Gaz. wrote: If you think Renault are 100% to blame, would you care to suggest where RBR will get an engine from for 2017?
An overwhelming part of the blame falls squarely on renault's shoulders, and I fail to see any relevance in that and RB's engine supplier in the future.
Didn't RBR ship in a load of their 'experts' last year in order to accelerate the 2015 engine?
Sorry, but if they're hiding the build of their car from their engine partners (they are, let's be honest, the defacto works supplied team) and asking them to accelerate the development in the wrong parts, then they're part of the solution. If they're part of the solution, then they're part of the problem too; you can't say we want our people to help and then complain about the output.
Facts Only
Facts Only
188
A lot of people said back in 2012/2013 when Toto AND Niki were drafted into Merc that there were two many chiefs at Mercedes but when you have a team and the engine supplier arguing/fighting this is exactly where you need someone above both to take the decisions.
Red Bull maybe the Renault works team but there is no-one (certainly not a strong leader like Niki or Toto) above both of them to make the final decision and stop the disputes.
I think Ferrari have seen how this has worked and is why they have brought in Maurizio Arrivabene who is affiliated to neither engine side or chassis side and so can take the decisions that need to be made. Toyota is a strong example of how even an outfit with engines and chassis in the same building can fail without cooperation and a strong leader, everyone I know who worked at TMG during the F1 years has said how toxic the atmosphere was between engine and chassis sides.
Red Bull don't need an engine team in the same building but they do need them to be under the same leadership.
Jolle
Jolle
133
Somebody at Renault (with or without RedBullRacing's consent) made the decision not to use all tokens. At or even before the first test of 2014 they knew they had a lot of development to do to catch up Ferrari and Mercedes. How is it possible then that they, with a whole years of development used the least tokens of the three plus putting non tested hardware on the engine for the first race
SectorOne
How does engine contracts work? Are they done on a yearly basis? Could Renault if they choose, decide to not supply Red Bull next year for example?
dans79
267
SectorOne wrote:How does engine contracts work? Are they done on a yearly basis? Could Renault if they choose, decide to not supply Red Bull next year for example?
I assume it's like any other multi million dollar contract, and has different opt/buy out options.
201 105 104 9 9 7
Gaz.
Gaz.
They are contracted to supply RBR until the end of the 2016 season, they can choose not to renew without penalty obviously but I would have thought there would be penalties from either side if one wishes to part company early although they could agree to go their separate ways if it suits both parties. I think that's a round about way of suggesting all options and that I really don't know :D
Forza Jules
raymondu999
Facts Only wrote:A lot of people said back in 2012/2013 when Toto AND Niki were drafted into Merc that there were two many chiefs at Mercedes but when you have a team and the engine supplier arguing/fighting this is exactly where you need someone above both to take the decisions.
Very good point, Facts. To an extent, that is the function in which James Allison now serves, I think - he's leading both the engine as well as chassis programs.
I remember someone made some similar comments (on a more micro level) with Red Bull vs McLaren in 2010 and 2011. It seemed like the McLaren cars were made by delegation - someone designed the best front wing, the best chassis, the best diffuser etc and bolted everything together and hoped it would work. Whereas the Red Bull seemed like a complete package all thought out together.
Without a unifying direction, I don't think it can work, really.
失败者找理由,成功者找方法
Kingshark
Kingshark
Back in December 2014, the managing director of Renault Sport F1 claimed that Redbull should also shoulder some blame for a sub-par chassis this season:
http://www.eurosport.fr/formule-1/saiso ... tory.shtml
Does the RB10 have the best chassis? "asks the French manager in the columns of the magazine Auto Hebdo, published on Wednesday . " It is said to be very sensitive to adjustments, unbalanced, has a delicate operation of tires. Well, it is true that with more power, you can put more downforce and with more downforce, the chassis gains in stability and in keeping tires. This is why we must get out of this reciprocal permanent indictment to better work together and achieve the best performance in turn, more than the best engine power. "
"As soon as we want to enter into a closer relationship, it is very complicated"
Asked how he felt about the union with Red Bull Racing, Cyril Abiteboul does not really show satisfaction. " Let's be clear, this is not good , he considers . We are unable to take our partnership to the level where I would like it to be: in terms of technology, marketing, respect, trust, transparency, positioning ... But I know well and I have a huge respect for what they do and what they built. The problem is probably in this success and in the method. They operate either in the role of the absolute control of what they produce or in that of absolute customer waiting for the supply of finished product delivered, performance and optimal reliability and, if possible cheap. As soon as the we want to enter into a closer relationship, it's very complicated. "
" Some couples may very well live well and others less well. For me it is a real disappointment. It is one of the goals I had set my roadmap back in Viry-Châtillon. Certainly, there is progress, but it is marginal , "he concludes.
So Red Bull blame Renault for not wanting to cooperate, and Renault blame Red Bull. Interesting...
this marriage/relationship isn't going to last much longer.
djos
113
It might not have been the best chassis but it was clearly 2nd best at worst! That much was obvious by how bad Renault's PU was in all the cars using it and the fact that Danny Ric managed to win 3 races despite having a donkey in the back of his car!
Kingshark
Kingshark
In 2014 the worst engine on the grid was Ferrari, this was highlighted by the fact that Toro Rosso comfortably destroyed Sauber, despite Sauber being clearly the superior team in previous years, and being faster than Toro Rosso so far this year (now that Ferrari have improved their PU significantly).
