2017 F1 general testing thread
noxroxafox
noxroxafox
Re: 2017 F1 Pre-season testing February 27 - March 2/ March 7-10
Anthropolyte wrote:Very peculiar. Can't think of anything it would go through to other than the rear of the intake, so perhaps some sort of bypass that releases air at high speed?
I was thinking something similar.. More like it can release some air to 'make' a blown T-wing or something
Restomaniac
Restomaniac
PhillipM wrote:With the lower rear wing, are they testing to see if venting some of the hot air out of the top and let the T-wing loft it so it doesn't interfere is better than venting out of the rear of the sidepods given there's less room from the bigger diffuser and tyres?
Sort of like a chimney?
Is that a hole or is it flat, because if it's flat it's just like the Williams.
If you look at the new engine cover the ducts seem to wrap around either side of the airbox - there's a bulge there.
Mr.G
34
noxroxafox wrote:https://pbs.twimg.com/media/C5rQ77kWcAI0hUJ.jpg
That looks interesting?!
I don't see any benefit from this solution :shock: Titanic chimney .
I also posted this in the car thread:
mwillems
44
godlameroso wrote:Is that a hole or is it flat, because if it's flat it's just like the Williams.
It looks like it has a silver lip around it so I'd say a gap. It also looks like the fin stays that wide right down to the engine cover. but it is hard to tell from that picture.
Edit: There's the answer....
-Bandit
dren wrote:
godlameroso wrote:I'd say it's most likely a valve within the oil system than the actual pump, unless of course it's an experimental pump, and they're doing something clever with it
I'd say they are probably pumping oil with their oil pump.
Right but besides lubricating the rotating and reciprocating assembly inside the engine, there's other places you can pump oil to. There's external tanks, and other things we know nothing about, with various valves, and check valves and fittings.
joseff
Hole on top of fin looks like a chimney exhaust for cooling. The radiator is at the top of the Mercedes logo.
Restomaniac
Restomaniac
If that doesn't effect the Aero then its a very clever way of dumping extra hot air.
Nidhogg
Nidhogg
A chimney slit. But what if it rains? I hope it won't cause moisture problems.
mwillems
44
joseff wrote:Hole on top of fin looks like a chimney exhaust for cooling. The radiator is at the top of the Mercedes logo.
Yes you can see that the gap in the wing is about 90 degrees to the cover, and about 45 from the ground, the whole fin opens and closes around this "chimney"
-Bandit
downforcemax
downforcemax
PhillipM wrote:Is it me or does it look like Merc are running a very low rpm limit today across all the engines? That's 3 Merc cars all recording 276.9kph at the speed trap...and the Mercedes itself is as close as makes no difference too.
where can i find those speed trap records.......thx
Arzu
Arzu
https://twitter.com/AlbertFabrega/statu ... 8625492993
Boullier: "Lets hope the issue only affects this engine. We are investigating it. Yesterday everything was perfect. This is test"
Moose
Moose
52
Typically the airbox splits into many different tubes that run to different coolers. There's nothing to say that a hot air exhaust can't run through the gaps between those tubes.
