Williams FW40 Mercedes
Re: Williams FW40 Mercedes
The bulge in the engine cover and the top of the rear fin suggests Williams might be going to run a chimney type air exit the same as Merc.
Best glimpse of the barge board behind the barge board i could get.
I still haven't quite figured out if there are some tricks hidden under the nose.
LookBackTime
LookBackTime
472
I see two dark dots above the bargeboard ! New aero bits to come ?
That's not dirt on my monitor? lol
Maybe that horizontal fin Mercedes and Haas have.
LookBackTime
LookBackTime
472
Sevach wrote:That's not dirt on my monitor? lol
No. You can see them on both sides of the car. Look at the last two pictures !!!
Ok i was kinda joking man, i saw your point =D>
LookBackTime
LookBackTime
472
Thanks to shorter tea tray FWs are closer than ever to the ground(except for those Red Bulls that had them flexing like crazy).
What goes under them can be crucial.
roon
roon
412
Rear wishbone mounts to the same substructure as the rear wing pylon.
Williams & Merc pursuing similar mirror treatment. Recessed.
roadie
39
I'm most interested in the bargeboard/leading edge of the floor. There's definitely something going on there with the leading edge so high.
I'm off to scour for photos.
Suspension arms are perfectly lined up either with the hot air exits and diffuser, top and bottom ones respectively (and obviously).
edu2703
edu2703
32
tomazy
tomazy
218
I think there is a vertical cooling slot under powerd by Mercedes-Benz.
