Toro Rosso STR13 Honda
Thunder18
Thunder18
Re: Toro Rosso STR13 Honda
RZS10 wrote:
12 May 2018, 13:09
Was the crash so severe or is the back end of the STR flimsy (potentially compromised bc of late PU change) ?
Turn 9 is near flat out depending on car/driver with not a lot of runoff area too. Fairly substantial crash and lucky to only come away bruised.
BrunoH
BrunoH
i was surprised it was so fragil to be honest..
Big Tea
99
BrunoH wrote:
14 May 2018, 11:47
They had a plank nailed underneath holding it together.
roon
roon
412
iichel wrote:
12 May 2018, 13:39
Poor car
right click -> "open in new tab" for more size
https://pbs.twimg.com/media/Dc_kVsVXcAI ... name=large
Looks like the turbo fell out.
AJI
AJI
27
roon wrote:
15 May 2018, 01:03
iichel wrote:
12 May 2018, 13:39
Poor car
Woah doctor... That is impressive!
GhostF1
GhostF1
110
AJI wrote:
15 May 2018, 03:14
roon wrote:
15 May 2018, 01:03
iichel wrote:
12 May 2018, 13:39
Poor car
I must be blind, I can only see the exhaust. Where's the turbo?
Singabule
Singabule
roon wrote:
15 May 2018, 01:03
iichel wrote:
12 May 2018, 13:39
Poor car
Exhaust only, engine is deeper. The turbo wont fell out if the engine not thrown.
Hino
Hino
64
roon wrote:
15 May 2018, 01:03
iichel wrote:
12 May 2018, 13:39
Poor car
When the rear end came off, it pulled off the turbine/wastegate exhaust manifolds. If your familiar with the Honda PU architecture, they use the split turbo design with the MGU-H in the middle, compressor/turbine hang off the ICE. If you look closely you can the spindle from the gearbox protruding.
HPD
198
The accident recorder provided the following data. The impact with the tail ahead was 110 km / h. A delay of 25G was measured. On impact, the tail of the Toro Rosso hooked up with the Tecpro elements of the barrier. The car broke apart between engine and transmission.
https://www.auto-motor-und-sport.de/for ... p-spanien/
Owen.C93
Owen.C93
177
So what are the thoughts on the pull rod suspension layout. It's very rare we get to see how they are designed anymore as they're deep in the gearbox casing.
It looks like they have 2 connections between the left and right hand torsion bars. The lower one could be the damper, and the top one looks like an anti-roll bar, but the way it's setup is backwards so it looks like it would induce roll?
roon
roon
412
The topmost one looks to be a rigid link that locates the distal/immobile end of the torsion springs. Changing the length of that member could alter ride height; whether it is changed out frequently or a permanent structural member, I don't know. Further in from that piece is the heave element. ARB might be tucked away in there but I can't make it out.
ScrewCaptain27
577
The wishbones also look like they have a very thin internal main structure with a hollow aerofoil cover.
- Serj Tankian
FrukostScones
163
Hino wrote:
14 May 2018, 01:08
RZS10 wrote:
12 May 2018, 13:09
Can't be surprised, its the gearbox and rear suspension. Although they did have to modify the gearbox to bolt on the Honda PU, I wonder if it means anything?
the spacers were a bit fragile :mrgreen:
HPD
198
bigblue
https://www.crash.net/f1/feature/896664 ... -wednesday
Toro Rosso has brought a new floor update to Monaco ahead of the race weekend. Gasly will get use of it from FP1 on Thursday, but teammate Brendon Hartley will not get the update until final practice on Saturday.
