Yes that was a close call. If Hamilton wasn’t on his toes, that could have been real ugly! What’s it gonna take before we see a major accident with these slow cars sauntering down the middle of the track, in this case two side by side?
Why would they use "detuned" mapping? It's of no use. They have to use the same mode in quali and race. They have to test that mode in FP.Xwang wrote: ↑05 Sep 2020, 13:10Someone could have used a "detuned" map in FP3 so that to sandbag and meantime reduce the number of kilometers/minutes run on the higher performance map, because, as far as I have understood they can use whatever map in free practice sessions. From the beginning of the race they can use only one map (except for safety car and formation laps).yelistener wrote: ↑05 Sep 2020, 12:53Since they can only use ICE in one mode, FP3's laptime could be very close to the Q3 performance. They can now only run higher MGU-K mode in Quali.
Didn't watch practice then?
If Merc could beat last year's pole by .3 it would be high 18's. With the party mode ban, they may be slightly slower. 19.5 maybe?
Depends where the pump is. If it's the low pressure pump, it is in the fuel bladder. Not so simple. The secondary high pressure pump is on the engine, which means it's easier to access, but may be more complicated to replace.
