Aston Martin AMR24
issey
issey
Re: Aston Martin AMR24
22 Feb 2024, 23:19
Vanja #66 wrote:
22 Feb 2024, 08:54
High Res flow vis photos. The inlet seems very sensitive but it works, there's a couple of paint streak going down into the ducting right above the bottom lip curve
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
That inlet flow is a bit scary to be honest. Probably closer to stall than what we saw from the RB. It's an aggressive direction change considering the incoming flow angle. The rest of the sidepod viz looks great though.
We also need to take in account that Stroll lost his left mirror while he had the flow viz on, exactly where the intake.
issey wrote:
22 Feb 2024, 23:48
22 Feb 2024, 23:19
Vanja #66 wrote:
22 Feb 2024, 08:54
Excellent point! The mirror sits above the inlet so it helps the flow to turn.
A lion must kill its prey.
FNTC
FNTC
I think he had driven a considerable part after exiting the pits though, so it might have already been dry? Not sure. If not I agree it definitely affects it, since the inner part of their mirror stay slopes down to feed the inlet.
KimiRai
KimiRai
298
Merc rear suspension components.
AMuS
Egresi Tamás
Egresi Tamás
Did you notice any new parts, or changes?
hollus
Posts talking about gained tenths have been deleted or will be shortly. The posters got (get) the text back, you are welcome to post them in the team thread or, perhaps better, the race threads.
As usual every year at this time:
a) Welcome to all the newbies!
b) No lap times, no track or championship position, no winning and losing in the car threads. Only hardware here, winning and losing goes in the team and race threads. Thanks.
In this case a few posts were moved to the team thread, but in general, we might just delete, moving takes a ton of time.
auem123
auem123
From Fabrega :
vorticism
323
𓄀
Egresi Tamás
Egresi Tamás
It is new?
dren
227
Same as in testing.
Honda!
abhi1200
abhi1200
Alonsismo
Alonsismo
Redragon
19
what's this grey box on top of the left sidepod and inside orange marker?
https://ibb.co/Xbdtqgs
https://ibb.co/c8fc73y
