marcush. wrote:
as always ..in testing ..are you sure the test has any significance to what happens in reality?
so if you need air to model the cooling down ...I´d say this is fairly easy technically to solve...
But how to have the drum held at a constant temperature your tyre is worked against?..
Like I said do I spend a lot of money making the test more realistic, or do I just go straight to reality and do a track test.
As it stands it's much cheaper and quicker to go track testing than rig test.
Even if you set up an air blower and a belt cooler - it's still a belt and the track surface isn't representative.
It's like damper dyno, you're constraining the damper to a predefined velocity profile and measuring the forces. In reality the low speed damping forces prevent a lot of the higher velocities ever being achieved - this is why 4-post rig tests are good. On a flat-track I'm forcing a tyre to follow a fixed set of conditions when in reality the forces and moments generated might cause other feedback to occur that gives the driver a totally different perspective than what you might expect.
On a flat-track the load is constantly applied. I'm sure you could do something more representative, but then you loose the generality that allows you to compare options.
People miss the point of testing like this, it's not to get as close to reality as possible, it's to have a repeatable proxy for reality that allows you to filter concepts. The only truly representative testing for most things on a race car is the race car on track.
Ben
