Just_a_fan wrote:Also the rules define a maximum width for the fuel tank - 400mm either side of the centre line IIRC.
assuming each team carries 250kg of fuel:
density of fuel is 737kg/m3 that's 0.339 m3
400mm of either side is 800mm width. That's the only restricted limited dimension.
Looking on drawing 5 with side protection foam in the tech regulations, the tank can be anywhere around 600mm above the reference plane.
Since we're not using a fixed shape there are infinite ways to fit 250kg in a tub.
for example using the widest dimmensions of 800mm and just using a 600mm height:
0.339/ (.8 * 0.6) =
0.706 m long
using say 380mm on either side instead of the maximum 400mm; 760mm wide:
0.339m3 / (.76 * 0.6) =
0.743 m long tank.
This is just using a simple rectangle to illustrate.
What we have there is the same capacity of fuel, but one tank almost 4cm shorter though 20mm wider.
And it can be much more extreme than that considering that we're not dealing with simple rectangles in reality.
edit: my fuel mass value may be wrong, but it still proves the point.
