They have a big update for Spain I believe.NathanOlder wrote:[...]
Does anyone know when ferrari plan any more upgrades for their car? Will they have to wait until Europe ?
Could be great for Ferrari, but terrible for Caterham!xpensive wrote: Mike Gascoyne seems to be on his way out of Caterham, my wet dream is to see "The Rottweiler" at Ferrari, what a match!
Given the car is so bad (so far) an all-new approach might be called for:xpensive wrote:How's that Don, imagine Montezuma, Gascoyne and Lauda the advisor, sparks would fly, such a shame that Eddie Irvine has come of age, or we could have seen some serious fireworks in the pits?! Nothing for the faint-hearted to behold.donskar wrote:Hmmmmmmmmmmmm . . . .Surely a marriage made in Hell!xpensive wrote: ...
IF what we are seeing is a true indication of the car's ultimate performance, then they need much more than an "update." I don't think relocated tailpipes will be a silver bullet. But, then, I was totally inept as an M.E. student!radosav wrote:we all saw ferrari is hard to drive. fernando in Q2 made time on used softs 0.2 sec slower than webber. massa was 1 sec slower than fernando because he couldn't cope with that car and push it to the limit. if they ever find balance on that car, or mechanical grip, will it be enough for that 1sec they need? i mean ,now they can homologate new chassis during season and ferrari will do it. what do you guys think?
To my mind, given my limited mechanical knowledge, they are going to be much more limited in how they can react to handling issues with that pull-rod versus the push-rod that others use. You can do things like move the push-rod backwards or forwards that you're going to have major difficulty doing on the pull-rod alternative.xpensive wrote:The front suspension comes to mind, I'm still very suspicious of that geometry.
Not heard that one. Interesting.xpensive wrote:Mike Gascoyne seems to be on his way out of Caterham, my wet dream is to see "The Rottweiler" at Ferrari, what a match!
Not sure I agree with this. How are you coming to these conclusions?Uniracer wrote:Agree with other posts about the unusual front suspension on the Ferrari. It looks like the front roll-center must be really high. That's pretty sure to cause understeer on pitch due to acceleration, and poor stability over bumpy corners.
For sure there are many things that determine the weight transfer of the front end. I have never seen any race cars with angled down front wishbones like used on several of this years F1 cars. Within normal range of roll centers it might not be significant, but the new design is certainly very "Different". If I am right, the car may work better on less bumpy tracks. I could easily be wrong, since the designers obviously implemented this design for a reason.Jersey Tom wrote:Front geometry doesn't look at all suspect to me. Different? Sure. Weird? No. High jacking coefficients on the front axle are just that.. not necessarily an indicator of overall balance. Could just as easily make up for the increase in front geometric load transfer with less front elastic roll stiffness or more rear. With how stiff these cars are in roll I'd suspect that the practical difference between geometric and elastic load transfer are much less than on other platforms.
High jacking geometry isn't that uncommon. Open wheel teams have done it to some degree, NASCAR teams do it, hell even FSAE teams have done it (somewhat inadvertently at times).Uniracer wrote:For sure there are many things that determine the weight transfer of the front end. I have never seen any race cars with angled down front wishbones like used on several of this years F1 cars. Within normal range of roll centers it might not be significant, but the new design is certainly very "Different". If I am right, the car may work better on less bumpy tracks. I could easily be wrong, since the designers obviously implemented this design for a reason.
Oh. So you can do CFD by eyeball and mental math then?C Plinius Secundus wrote:... I remember the principle of laminar and turbulent flow. IMHO, those acer ducts not only "deprive" from flow of air to the beam-wing, and create a low pressure area above the floor, but also interrupt the laminar flow above the sidepod, creating a turbulent air zone to feed the beam wing and rear wing. I may be completely wrong, or not, but in light of the results so far, I think those atrocities should be chopped off!
