astracrazy wrote:i do buy into ringo's theory. Maybe it was just too obvious solution, everyone is more concerned with flexi wings, ebd etc. The RB's have always been very smooth
If you look at Merc and Ferrari they have gone down the same route with there sidepod/engine cover design - they are very similar
I don't think this is 100% the reason for there success but i think it is one of the factors + other things. Its just has been overlooked
But, ringo, you said a few pages back you always back up your theories with evidence. You'll only prove your point with cfd evidence
mercedes and ferrari are not the same design. They are very different. It's not about smoothness.
You see it's not the general shape of the sidepod. It's the suttle difference in equation for the curves used for the sidepods.
And even still there is a massive difference with those three sidepods with geometry especially the ferrari.
Lotus, as i said before, is most similar to redbull. both this year's car and last year's.
this was made when the mclaren l pods were around as a simple example for one of the threads. I posted this but obviously never said what x was.
and as much advantage that the l pods have in pressure recovery over the top, the redbull still had superior pressure recovery near the rear end, and also better flow energy. more red is better in this context above. and this is with no rake.
there should be more images with a typical side-pod comparison.
Tests were done and model refinements were made etc. etc. until i decided to copy the redbull design philosophy on the 3d model car.
I'll be glad to run the cfd on the body of the car, but the file was messed around with since then, so i'll have to clean up things a bit before the cfd runs without error. if anyone else has another car out there, we can compare results for the body only.
