Blackout wrote: ↑23 Sep 2017, 16:18
IMO one of the reasons that intake plenum is so swept forward is the need to free as much space as possible at the back of the V for the new compressor air duct... The new turbo seems to be much compact and closer to the PU,
and the new compressor's intake has been placed inside the V, à la Ferrari, IMO (while it was outisde in 2014-2016)...
And maybe that plenum hides a small air-water intercooler too... or a diaphragm-like system
So I was right... except for the red part
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
As you can see, the compressor's airbox is now located forward of the engine's rear mounting points. That means the whole turbo hase been pushed forward. The red-capped disc-shaped airbox seems to hang inside the V.. well almost.
And the intake plenum bends forward to clear the way for the airbox... A 2014-2016 plenum would sit on the 2017 compressor inlet.
Couldnt find a good pic, but the 2014-2016 PU had its airbox aft the v6 mounting point so outside the engine.
So 2017 engine "2nd gen" is shorter/more compact.
Which, on paper, brings some benefits regarding weight distribution, pipework/lag, gearbox size/aero etc
![Image](https://i62.servimg.com/u/f62/14/79/55/26/5okdv910.jpg)
