what is most limiting revs in af1 engine ?
Ciro Pabón
106
JohnnyBoy wrote:Maybe the gas turbine could be used to power an electric generator...
How long will it take for the new technologies to be applied in motorsport!? Maybe not F1 but surely it will start being used in racing soon, i think!
Well, I use to tell a tale about car engineering being one of the most conservative forms of engineering around. It is a long one, and some of you have heard it, probably, because it is around the Internet, but here it goes on my own words:
"Back in the roman empire times, Julius Caesar ruled about the legal width of a horsecar. The idea was that the width should be standardized because the wheels were really narrow and they produced ruts all over the road.
This was a feature hard to change for an individual horsecar maker, so this width hold for centuries, long after the fall of the Roman Empire and the Feudal ages.
Then, when the railroad was invented, James Watt had to use the same tracks used by the old horsecars on mines, that naturally, had the standardized rut width, so the width of the UK tracks became the same as the roman roads.
On time, british exported the railroad around the world, and the width of the british track became the standard in USA. A century of "progress" passed and the americans took part on the space race.
When the thiokol rocket for the Space Shuttle was produced, one of the factors in designing it was the width of the railroad tunnels it will have to pass, given by the width of the american railroad track, given by the width of the british track, given by the roman 44 BC law.
So the most advanced vehicle on earth has a width that is roughly equal to the width of the butt of two horses."
So much for car engineering and quick progress, I'd say... The lesson here: next time you dictate an standard, think carefully about it. It can live longer than you expect.
Ciro
flynfrog
So your saying my declaration that all thursdays be naked day could last forever :shock:
Ive studied teh turbine indy cars alot they realy should have one 2 years in a row but were put out with no turbine problems lasp ahead of there competitors
but rember in indy you never lift perfect for the trubine but it wasnt the turbine that made it grate it was the awd they could run the car any where on the track it was actuly down on power compared to the others out there
but in there day they were amazing machines well they still are ive seen them in person
Indy evntualy phased them out but if they hadnt and chrysler would have buiult there trubine car i think we would be driving them now
a turbine electiric car is what i think we will be heading twards in the next 50 years moslty because they will run on any thing that burns and the are efficent
Guest
Guest
"FIA president Max Mosley believes his plans to introduce energy-saving technology to Formula 1 will revolutionise the development of hybrid road cars over the next decade.
Mosley last month invited F1’s major manufacturers to come up with a new engine formula for 2011, when the FIA plans to impose a limit on engine power through the amount of fuel burned instead of the traditional means of engine capacity size.
He hopes that this will encourage car makers to introduce hybrid technology to their Formula 1 programmes." (itv.com/f1)
That should put the cat amog the pigeons!!!!
Ciro Pabón
106
andyinglis wrote:"FIA president Max Mosley believes his plans to introduce energy-saving technology to Formula 1 will revolutionise the development of hybrid road cars over the next decade..."
We argued in a thread about that... but we did not talk about FIA politics. Actually, rereading it, we were pretty naive... :roll:
Ciro
DaveKillens
DaveKillens
34
Gas turbines may appear cool in racing applications, but they have severe drawbacks. They are gas hogs, put out a LOT of hot air, and have severe lag.
The M1 Abrams tank will always endure severe criticism because it uses a gas turbine, and makes the machine seem impractical in some scenarios. Troops cannot ride on it in urban warfare situations, it cannot sit and idle for hours in a defensive position, and the need for fuel creates a logistic and operational nightmare.
Personally, if Max wants to lay the groundwork for future efficient cars, make them run nothing but hydrogen. It's as green as you can get. Then issues such as safe storage and efficient engines can be aggressively tackled by the engineers.
Ciro Pabón
106
Dave, you can say hydrogen is a green technology, in the sense that does not spread pollution. I'd like to add that "green technology" is a "broad label".
A more restrictive one is "renewable source". I do not think hydrogen qualifies as renewable. In this sense, is more of an energy storage system than a fuel, as it does not occur naturally: it has to be created from other "real" sources. Overall pollution depends, probably, on that "real" part of the energy system.
Hydrogen has another problem: it can be created "cleanly" (for example, through electrolysis) or in a "dirty way" (chemical subproduct). Guess which one is the cheaper and is the preferred one of the actual hydrogen industry... O:)
Ciro
DaveKillens
DaveKillens
34
Of course, the industries want to burn oil or other renewable resources to give the consumer hydrogen. It gives a good return to the investor.
My thinking, though, that if we ever got a consensus (not likely or going to happen in my lifetime) from the politicians, hydrogen could be manufactured by "clean" renewable resources. The wonderful advantage is that the byproduct of burnt hydrogen is water.
Maybe one day we may see Formula One cars powered by fuel cells.
http://www.electronickits.com/kit/compl ... elcell.htm
flynfrog
DaveKillens wrote:Gas turbines may appear cool in racing applications, but they have severe drawbacks. They are gas hogs, put out a LOT of hot air, and have severe lag.
they are air hogs not nessiacarly fuel hogs they tend to burn the fuel more effecently too when used with recovery turbines
to idle they simply need enough fuel to keep spinning not to mention the massive amount torque off idle
ive seen city busses using turbine electric hybrids
check out http://www.allpar.com/mopar/turbine.html
DaveKillens
DaveKillens
34
I am using the M1 Abrams as a comparison because it there are similar tanks that use diesels. So direct comparisons of different powerplant types can be made.
The Abrams has been around since 1980, so it is a mature design. It too uses a regenerator, but unlike prototype cars or technology demonstrators, it is a practicle working machine, having to be used every day and thus real world problems cannot be ignored but dealt with.
flynfrog
i agree the engine in the M1 was based off of these prototype cars chysler was design the tanks around the same time i belive
they had the same problems heat at idle and fuel consumption at idle but couple this with a hybrid drivetrain where you can run the turbine at full efficency and shut it off when idling ect it becomes viable
ginsu
ginsu
Audi has shown that TurboDiesel technology is ready for racing. They destroyed the gasoline powered Pescarolo's in Le Mans this year, even holding back they had a 2-3 sec advantage per lap. Now, I'm not saying the TurboDiesel is ideal for every race track (i.e. monaco might be a nightmare), but it's possible it could be developed to a very competitive point. After all, you can run a low fuel map and get 80 mpg, then a high fuel map and get 800 ft/lbs of torque. Current F1 v8's probably don't get much above 200ft/lbs.
Hybrids will certainly be the future, and we should develop it, but TDI power is already here. Although, I think it would be fun for every car to have a different type of engine technology.
I love to love Senna.
pyry
pyry
monaco would be a wet dream. high torque, low consumption. a diesel on full throttle doesnt have nearly any economy advantage over gasoline, but during part throttle it saves the most
four rings to rule them all
Powerslide
I wonder who was the engineer who wanted to use a 4 wheel drive system on a turbine engine to race in ovals. Sounds more flash than dash to me. If there is no torque in a race that does not need acceleration then 4 wheel drive is pointless. The tubine engine on an oval can be promising because of its ability to produce horsepower without concerning torque.
:cool:
Ciro Pabón
106
Powerslide wrote:I wonder who was the engineer who wanted to use a 4 wheel drive system on a turbine engine to race in ovals...
Actually, there were several. He was an engineer that lived in a country where it rained... :wink:
Ciro
