Very interesting.
Just re-watched US GP, lap 29, Webber pit stop.
Rearward facing camera, when the car comes off the jack, the tea tray stay bends significantly, just coming off the jacks.
Do a bit of a search. Its already mentioned in here.Roonaldo wrote:Very interesting.
It makes sense: more than it - it is common practice. If you want something to flex on the car, you usually use fiberglass.flynfrog wrote:that doesn't really make much sense. If you want to to flex more use less carbon. They use carbon for the cosmetic body panels not glass.shelly wrote:@CBeck113: I would liek to see it too. I have seen that on Gazzetta dello Sport Piola has published a more detailed drawing; probably this week it will be published on Autosport too so it could give some better idea.
@flyinfrog: I think that you do not need such a massive structure in carbon to withstand the proof load - my idea is that the bridge is a flexible cover - that's why I think it is glass. If it is carbon, seeing the weave could give some hint anyway
You can get the same flex out of carbon with less weight and volume why would you use glass?shelly wrote:
The bodywork is made of carbon, the vanity panel in the 2013 noses is fiberglass (it is in the rules iirc).
@cbeck: what translation?
the suspension flexures are carbon. so is the "flexy-wing". it may be that in production items, it is easier (and certainly cheaper) to manufacture flexing parts of a specific stiffness with fiberglass.shelly wrote:It makes sense: more than it - it is common practice. If you want something to flex on the car, you usually use fiberglass.
The one from here http://www.omnicorse.it/magazine/33275/ ... nel-t-trayshelly wrote:
source: http://blog.axisofoversteer.com/2013/12 ... r.html?m=1It was a surprise then when in Brazil, thanks perhaps to the team being a bit more relaxed, a photographer was able to snap a picture which showed the inside of the t-tray and keel assembly
Where did you get the info about flexi wings and suspension flexures being in carbon? Some years ago they were made with fiberglass - maybe the technology has evolved and now they are made in carbon. Anyway the loads in that cases are higher - for the t-tray glass would be still an option.thisisatest wrote:the suspension flexures are carbon. so is the "flexy-wing". it may be that in production items, it is easier (and certainly cheaper) to manufacture flexing parts of a specific stiffness with fiberglass.shelly wrote:It makes sense: more than it - it is common practice. If you want something to flex on the car, you usually use fiberglass.
@flyinfrog: you cannot get more flexible than 1 layer of carbon, that's why glass is a good option.For example in the regsit is prescribed taht the rear wing spacers cannot be made in a material with modulus less than a certain threshold, specifically to ban fiberglass
galvanic corrosion, you can also alodine the aluminum or wet install. Its really more for planes than limited use race carsthisisatest wrote:Similarly, one would sometimes use fiberglass as a "scrim" layer (dunno why it's called that) between carbon and, say, aluminum hard points. Otherwise they will corrode and separate.
flynfrog wrote:http://assets.f1-fans.co.uk/img/full/125146836332.jpgshelly wrote:
http://www.gurneyflap.com/Resources/DSCF0272.jpg
You can always tailor your flex by your layup pattern or drop you fiber count going to a 3x fiber over a 12k would be a pretty big drop. one ply of carbon would be incredibly weak not really an issue here.
Unless you are worried about electrical insulation or trying to match a CTE glass is for boats not race cars.
