i meant by those heat shields...........white color confused me....they are supposed to be silver..aren't they? or they are not heat shields at allgilgen wrote:Which white coers?auto saibot wrote:are those white covers permanent?
forty two,forty-two wrote: Some drawings in the "Reducing the drag of a two element wing through stall" thread suggested that a fluidic switch can work like this, or with careful tweaking could be made to work without a secondary signal.
Perhaps RB decided it not too much of a loss to have two lots of ductwork instead of develop a single signal fluidic switch?
While I don't disagree with you on the idea, I think that this picture is a little misleading. The holes you see in this image are, I believe actually the front edge of the splitter, not the mounting holes for the splitter. Some other pictures from this incident show that the splitter remained attached throughout.speedsense wrote:forty two,forty-two wrote: Some drawings in the "Reducing the drag of a two element wing through stall" thread suggested that a fluidic switch can work like this, or with careful tweaking could be made to work without a secondary signal.
Just thought I would point out something pointing to your post of sliding the splitter in and out. In this picture is something very strange (having built a few splitters myself)... two square tubings that apparently have the splitter mounts slide into them, as they proceed the location of the splitter. If this is the mounting of the splitter with matching smaller diameter tubes inserted that were hinged and slid inside for static tests and back out for running, it would follow your theory...
they could be coated, like airfoils in the jet engines (the ones in HPTs, for example).auto saibot wrote:i meant by those heat shields...........white color confused me....they are supposed to be silver..aren't they? or they are not heat shields at all
Lol, iirc Mark & Seb tested KERS in the RB5 once in the off season but Newey decided the car was faster without the extra weight!marcush. wrote:I got the feeling RBR7 will not be the class of the field...they will struggle with their KERs as everyone struggled when taking it onboard.did RBR even test
a KERS unit yet? or will they not run it at all?
Now this...djos wrote:Lol, iirc Mark & Seb tested KERS in the RB5 once in the off season but Newey decided the car was faster without the extra weight!marcush. wrote:I got the feeling RBR7 will not be the class of the field...they will struggle with their KERs as everyone struggled when taking it onboard.did RBR even test
Newey talks about the packaging of KERS in the RB5 HERE:
