Less torque to reduce tyre wear?
thearmofbarlow
thearmofbarlow
Re: Less torque is illegal? Red Bull WTF
Look, I'll put it simply with AN EXAMPLE!
Coming out of the corner, the driver gently rolls on the throttle. The torque demand is even throughout, so he gets an even response from the car.
Coming out of the corner, the driver stabs the throttle wide open. AH! Well obviously you don't want to do that so now the engine's going to kick itself into STABBYTHROTTLEMODE and changes the ignition timing so that the midrange response is all kerfuffled and the car doesn't pull away as fast.
That is a type of traction control, based on user input. BAM! I win my own thread. Now everyone go have a snack and await the FIA's joyful clarification of this whole mess.
rjsa
rjsa
51
rjsa wrote: If it's open loop you can call it good traction, sensible traction, whatever you like best. But it's not traction control.
red300zx99 wrote:
rjsa wrote: It's like saying brake bias adjustment is ABS.
No, but if you had called brake bias a stability control system I would have agreed.
Call it stability shaping instead of stability control and you've got it figured out right.
rjsa
rjsa
51
thearmofbarlow wrote:Look, I'll put it simply with AN EXAMPLE!
You see, the point here is that if the driver stabs the throtle wide open, the engine *WILL* go 100% and it will skid seven ways to hell. What's happenning here is way subtler than that, it's not TC, it's only smart spark timing to get more, hotter air into the diffuser on partial loads.
Cam
45
By having a greater variation in its engine mapping, Red Bull Racing was able to both minimise wheelspin and also pump more gases through its engines, therefore helping the aerodynamic benefits that the outfit still gets through the use of exhaust flow at the rear of the car.
traction control
n
(Engineering / Automotive Engineering) (in motor racing cars) a method of preventing wheels from spinning when traction is applied by limiting the amount of power supplied to the wheel.
RBR minimised, not prevented. It's an important distinction.
― Socrates
rjsa
rjsa
51
traction control
n
OOOhhhh boy, you guys can't really be that blunt. By the definition used here, failing to press the gas pedal and crawling out of a turn will be called traction control.
EDIT for god's sake, dou you guys have acually driven cars, have you ever kicked a TC or an ABS in to know what it is about?
hardingfv32
hardingfv32
thearmofbarlow wrote:Coming out of the corner, the driver stabs the throttle wide open. AH! Well obviously you don't want to do that so now the engine's going to kick itself into STABBYTHROTTLEMODE and changes the ignition timing so that the midrange response is all kerfuffled and the car doesn't pull away as fast.
Why make a complicated map for a situation the driver can control? If the engineers knew to create a map for the situation, then the driver also knows that the situation existed. As presented by you, the driver can function with equal performance without special mapping.
True traction control does something the driver can not accomplish on his own, drive at the limit of the tires at all times and in any track condition.
Brian
Cam
45
From WIKI
A traction control system (TCS), also known as anti-slip regulation (ASR), is typically (but not necessarily) a secondary function of the anti-lock braking system (ABS) on production motor vehicles, designed to prevent loss of traction of driven road wheels. When invoked it therefore enhances driver control as throttle input applied is mis-matched to road surface conditions (due to varying factors) being unable to manage applied torque.
Again, prevent, not minimise. Prevent would mean none at all.
― Socrates
Cam
45
One can only make a car behave to the allowed regulations. Having clearly defined regs stops this kind of thing. But then again, do we really want stop it? This is the fun part. This is where we see tricks and innovation.
― Socrates
bhall
bhall
244
hardingfv32 wrote:Why make a complicated map for a situation the driver can control?
You're absolutely right. Such a development would go against the grain of Formula One's long-standing tradition of simplicity.
:wtf:
gato azul
gato azul
70
hardingfv32 wrote:I assumed that track tailored 'drivability' maps have been in use for many years.
There is talk that the 'new limit could allow as little tolerance in torque as two per cent'. Does this limit the options available for modifying 'drivability'? Are there traits of 'drivability' not related to torque output?
Brian
1.) Yes, mapping to "improve driveability" has been around for a long time, even for mentioned "trick throttle linkage" on the Honda's was an attempt in this direction ( improved driveability), and is probably still the main job of the application engineers.
I guess it's a question of the level of sophistication reached which the systems/ control algorithms used.
It's the difference between "mimicking" a nonlinear throttle linkage (cam or quadrant or whatever) in a drive by wire system
and a full blown model based controller.
2.) I would like to think so, it will make things a bit more difficult to achieve, but we will need to see, how the limitations are worded, before we can state what it will mean in the overall scheme of things.
3.) sorry, I don't understand your last point
thearmofbarlow
thearmofbarlow
Brian
So much facepalm...
aussiegman
aussiegman
105
Stradivarius wrote:5.5.5 specifies how the torque demand should depend on the accelerator pedal position. More specifically, it specifies that this dependence should be monotonically increasing.
What 5.5.5 does (in my opinion) is set down that at any particular RPM, for a given throttle %, where that % is increased then the torque demand (engine torque output requested by the driver by increasing the throttle %) must increase as a monotonic function.
Stradivarius wrote:However, a logical consequence of the rule is that the maximum accelerator position must correspond to the maximum torque demand.
Agreed, BUT (and this is the important part) it does not specify what is the maximum torque value or output of the engine must be under maximum torque demand which leaves that maximum torque value is variable and indeterminate from the engines theoretical maximum torque value.
As such, where any teams engine could make 400Nm, than currently they are able to reduce that maximum value to as an example 375Nm which in turn allows them to fulfill other mapping requirements within the mid range torque profile.
If the required maximum mid range torque exceeded that allowable within the provided variation and did not form a monotonically increasing function with a maximum value greater than 375Nm, then it would be possible for the engines maximum torque output to be less then its possible theoretical maximum such that even though it could produce 400Nm, it is allowable to reduce this to 375Nm for the benefit of mid range torque delivery . (These are arbitrary numbers).
I still hold that this is likely what RBR did, in so much as they determined a maximum torque value required and worked backwards so they could fulfill the mid range torque requirements while still forming a monotonically increasing function.
thearmofbarlow wrote:1) But they are not free to use a combination of throttle input and ignition timing to change the way the car behaves under acceleration. That is what this is about.
They are absolutely free to use the ignition and throttle input to change the way the car behaves under acceleration, however there is a proviso, that being that they do so in a consistent manner for the duration of the race.
What the FIA are disputing is that RBR was not consistent in their mapping as to the maximum torque output of the engine from event to event, not during the race.
Under the current non-clarified regulations, as long as the mapping provides that every time the driver inputs x% of throttle at yRPM they receive zNm from the engine, then the map passes regulation provided the delivery forms a monotonically increasing function.
hardingfv32 wrote:1) What exactly is 'engine torque demand'? what is the significance of adding the word 'demand'. This is no accident.
No it is not.
hardingfv32 wrote:This is not acceptable. I do not see the noun 'demand' have any measurable value. Secondly, why add the statement "or greater than the maximum engine torque" if you are talking about "basically...maximum engine torque"?
Firstly, who are you to deem what is or is not acceptable?! Manners, some social etiquette and a little common courtesy would go a long way Brian!! A simple I do not agree would suffice rather than trying to lord it over people by attempting to determine what is or is not acceptable. Some might think your attitude is unacceptable, however so far no one has ordered you “pull your head in!” Please play nice…
As to your desire to understand why “demand” is used, to my reading the word “demand” refers to the % of throttle manually input by the driver in requesting engine torque delivery, in so much as the driver has made a demand from the engine for an increase or decrease in torque delivery by altering the throttle % conveyed to the engine management system for a given set of conditions. It is present to stop teams from allowing the ECU to arbitrarily alter throttle % independently of driver input for the benefit of manipulating engine torque output vs. engine torque demand.
hardingfv32 wrote:2) How do you request 'greater than the maximum engine torque'? why would you expect to get 'greater than the maximum engine torque'. Again this wording is no accident.
This insertion of “greater than maximum” is a safety clause that were for unforeseen circumstances the engine produces in excess of what the FIA has deemed as an engines maximum torque value by any percentage then that car would not be excluded. Variations could come from altitude, temperature, atmospheric pressure changes or other variables. In defining “greater than” they are allowing for any increase over the expected maximum, no matter how infinitesimally small. If this was not inserted should an engine be expected to produce 400Nm and logging should that at one point of the race for 0.0001s it provided 400.000005Nm of torque, then the car would be required to be excluded.
Never approach a Bull from the front, a Horse from the back, or an Idiot from any direction
strad
117
To quote Juan Pablo when speaking with jeff Gordon during their ride swap..
"Just stab the throttle and let the traction control sort it out."
It's easier and more dependable. :wink:
Sir Stirling Moss
aussiegman
aussiegman
105
Regulation 5.5.3 states that:
5.5.3 The maximum accelerator pedal travel position must correspond to an engine torque demand equal to or greater than the maximum engine torque at the measured engine speed.
The minimum accelerator pedal travel position must correspond to an engine torque demand equal to or lower than 0Nm
Stradivarius wrote: Since the torque demand map must be monotonically increasing, maximum accelerator pedal travel position will correspond to an engine torque demand equal to or greater than the maximum engine torque at the measured engine speed.
Yes, however where does it mandate, require or describe that an engine maximum torque output must be equal to its theoretical maximum torque output or that this value cannot be independently assessed and nominated by a team using a particular engine?
Stradivarius wrote: If you violate this rule, the torque demand map can't possibly be monotonically increasing, thus 5.5.3 doesn't change anything and could be removed without any concequences. I then make the assumption, that the minimum accelerator pedal travel position would correspond to an engine torque demand of 0 or lower anyway, since all the teams make use of engine braking.
What 5.5.3 does is prevent teams from using the ECU and mapping from arbitrarily altering either the torque delivery function OR the maximum engine torque for benefit.
If on examination a team’s ECU was found to have provided variable maximum torque at 100% throttle and maximum RPM during an event, then there is a clear violation of 5.5.3 in my opinion and as such it cannot simply be disregarded.
red300zx99
red300zx99
traction control
n
You have data to support your statement that they didn't prevent wheelspin?
TC TRYS to prevent excessive wheelspin. No system is perfect though.
gridmotorsports.com
