Presumably it's hollow at the other end, and uses some fancy pants bearing to hold it in place somewhere along it's length.Maynard G. Krebs wrote:How do they get air INTO the axle?
The axle duct has nothing to do with bodywork.Maynard G. Krebs wrote:"The other end" being inside the bodywork, though? Doesn't seem like it would help much.
I can't envision how they do it without slots in the axle, but that doesn't seem helpful either.
We're talking about the front axle here, the other end is in the hub, it would be (relatively) trivial to get the air out of the break duct, around, and into the end of the axle.Maynard G. Krebs wrote:"The other end" being inside the bodywork, though? Doesn't seem like it would help much.
Williams FW35 - Rear End detail
via SomersF1/Sutton Images
Williams FW35 - Another shot of the revised layout inside the blown axle
Not really, the problem is more simply that to defend you end up taking a tighter line into turns, and slowing down more on the apex, where no move can be made, then taking a tighter line out again. It's not that aero is being cocked up particularly – it's simply that you're driving a line that's not optimal, but does cock block the person attacking you. Of course aero effects do have an impact, it's just minimal compared to driving a slower line.drunkmunky wrote:The aerodynamic wake of both cars would disrupt each other far greater than any single aerodynamic device.
This is why you see a lot of combating cars slow the grid down. It's not just because they are battling, but the 2x aero-effect of combating cars produce a lot of turbulent drag.
Hence the importance of a fast car to get into clean air asap.
