stefan_ wrote:iotar__ wrote:
Edit:
Leading developer driver came back to shorter-wheelbase, Lotus threw away FP1,2 data and went down like a brick, another success story.
The long and short wheelbase had the same performances, but they switched Kimi back to previous versions just to be sure. It performs the same way as the short one right out of the box and now it's a matter of squeezing that something extra from it. The LWB will return in Singapore.
It's not the first based-on-nothing tendentious post you make towards Lotus and I am not sure you are writing it because you are being hateful or a bit slow-minded to say the least.
I think qualifying proved my point
And based on nothing? My point is factually 100% correct and based on what actually happened. Connection is mine but v. likely, I'll expand later. Yours on the other hand IS based on nothing: "The long and short wheelbase had the same performance". Zero evidence for that, not enough proper comparison. Where did you get that idea Mr Quick Minded or Mr "I have no argument so I go straight for petty personal attack"? Provide it or apologize and shut up. No one admitted that, none is bringing big update like that that brings no gains, check N. Chester Spa interview.
Monza was a special situation of course but that's what you get when Lotus is run as a one driver team. Was Germany strategy rational? Was testing schedule and updates distribution in first (!) and second (!) race rational? Nope. Maybe Monza was but I don't think so. Why? Look they give update they meant to run earlier but couldn't to one driver. That's their policy, can't afford two
whatever. So they're running two independent programs, for "comparison". It's not the first time Lotus goes backwards on Saturday (same happened in Spa), here long pace was fine, one lap may have been questionable but overall OK. Check A. Permane after FP1-2 about it and also check what they said about running two different cars - NOTHING. That's normal too, they said nothing about team orders - it was "split tyre strategy" etc.
Later this is only thing we got: "the decision was taken because of a desire to be conservative rather than any issue with the long-wheelbase car, which Lotus is convinced is at least as fast as its predecessor." is this your "same performance"
No one with a clue is throwing "same performance" claims. You do know what performance is? What would be reference point for this performance in Monza?
What is this "conservative"? Reliability? IMO doubtful. So despite being convinced of its performance they ditch it, basically based on "feeling" of one driver, throw away half the data, it's easy to assume that they modify the other half to accommodate their leading, chosen driver (that's my connection between facts) and end up losing ground to the competition. How is today's qualifying result not expected after something like that? What did YOU expect smart-one? Tell me when did you see some other team with that half-hearted (literally) approach to big updates? For good reason.
Edit: After FP1,2:
That was a fairly straightforward Friday for us with both cars evenly matched and both drivers happy. We've completed a good amount of low and high fuel runs as well as evaluating the two tyre compounds for race strategy. Romain was happy on longer runs whilst Kimi's afternoon session was slightly interrupted with an engine water pressure issue during his long run, but this was no big drama.
Overall, the car looks quick, reliable and we're happy today."
