Caterham CT-05 Renault
Re: Caterham CT-05 Renault
No matter what Color they Paint that Nose, it will be ugly.
monsi
monsi
Owen.C93 wrote:Image
There are pretty brutal looking vertical tabs at the upper far corners of the wings. Will they be creating a lot of drag ? Can I presume the intent is to function as a gurney flap of some sort ?
FrukostScones
163
close-up:
much, much, much better
Regarding the sidepod: did it have that 'undercut' on the testing package? (at the left in the image)
Reason: Remove quoted post right above
MatthiasDS
MatthiasDS
Huntresa wrote:
erlik wrote:This looks better. Too bad that black paint can not improve performance of the car as it improves appereance of its nose.
The car is still faster then the Red Bull tho, but then again so is everyone :P
Ricciardo went 10th fastest in Bahrain if memory serves me well? With Caterham seconds slower?
Huntresa
Huntresa
But did Red Bull finish a race distance ? Unless they can time travel to the future, a car breaking down will not be fast.
MatthiasDS
MatthiasDS
No, they didn't. I did read an interesting comment on another forum forum though, by someone that had a meeting a few days ago with Caterham people. If he's to go by, Caterham was running relatively well because they hadn't cranked the engine up as far as RBR had.
Both are bad when racing: running with reduced power in order to finish, or running with full power but unreliably. In the case of Caterham, it makes sense to bank on reliability. In the case of RBR, they simply have to be running at full speed as soon as possible.
Anyway, good news for Caterham as well, Renault has just given the OK for running full power in Australia.
geraldix
geraldix
Look how small those cameras are. Surely they are attached to the nosecone in a way that half of them is hidden inside the vanity panel? Could Red Bull be planning something like this for their nose cameras?
idfx
Anyone have photo of the noise Catherham, this angle? Showing the internal part ?
example image:
Thanks.
cubejam
cubejam
19
Side shot from the TV broadcast of that engine bay
emmepi27
emmepi27
141
They have new upper flap on the front wing (ph Amus)
Comparision: https://pbs.twimg.com/media/BircqCYCUAAjr1T.jpg
Mandrake
Mandrake
Wow, that is what I would call an aggressive Front Wing. Look at the heavily curved elements at the endplates :shock:
mycadcae
Mandrake wrote:Wow, that is what I would call an aggressive Front Wing. Look at the heavily curved elements at the endplates :shock:
as to reduce the pressure
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
