One source says it was a warm up lap....timbo wrote:Xcept this not the first lap and they did quite some running before that happened.bonjon1979 wrote:There is absolutely zero point testing tyres in these conditions. What were they thinking?? 5 degree track temperature is so far out of the operating window. For some of the 'best minds in motorsport' they seem to be entirely brainless.SR71 wrote:Warm up lap I believe...
Something like 5c track temp.
Everything way out of spec.
And there are things you still can test even if the temps are not in the window.
There are things you can test with temps way out of the window, but, on that list, you wouldn't normally find "tires".timbo wrote:Xcept this not the first lap and they did quite some running before that happened.bonjon1979 wrote:There is absolutely zero point testing tyres in these conditions. What were they thinking?? 5 degree track temperature is so far out of the operating window. For some of the 'best minds in motorsport' they seem to be entirely brainless.SR71 wrote:Warm up lap I believe...
You can have more than one warm-up lap during a dayEddie_Temple wrote:One source says it was a warm up lap....timbo wrote:Xcept this not the first lap and they did quite some running before that happened.
https://www.autosport.com/news/report.p ... -tyre-test
Do you have a source for your version of events?
As for wet tires the anti-aquaplaning properties should not depend too much on temp. And it's relatively easy to get heat into wet tires, e.g. leave a piece of track dry. Also, I imagine wet-compounds should be able to cope with wider range of conditions than slicks.Pierce89 wrote:There are things you can test with temps way out of the window, but, on that list, you wouldn't normally find "tires".timbo wrote:Xcept this not the first lap and they did quite some running before that happened.
