They are huge compared to other teams for startersGiando wrote:Guys... something weird going on here with those brake cooling intakes...
Not much different than the SF2016H ones...Ray Okay wrote:They are huge compared to other teams for startersGiando wrote:Guys... something weird going on here with those brake cooling intakes...
That drop in height of the brake duct is a function of the camber angle and the caster angle plus the distance of the duct away from the axis. The axis of rotation has an inclination to it so this will happen.Giando wrote:Not much different than the SF2016H ones...Ray Okay wrote:They are huge compared to other teams for startersGiando wrote:Guys... something weird going on here with those brake cooling intakes...
http://i.eurosport.com/2016/02/19/17984 ... 0-1440.jpg
But I was rather focusing on what i've highlighted in green above the picture below... they do not seem symmetrical, meaning at the same height compared with tyre/upper suspension arm... are they moving up and down somehow when braking or it's just a mounting issue?
http://i64.tinypic.com/30mu7id.jpg
So car changes camber when it turns?PlatinumZealot wrote:That drop in height of the brake duct is a function of the camber angle and the caster angle plus the distance of the duct away from the axis. The axis of rotation has an inclination to it so this will happen.Giando wrote:Not much different than the SF2016H ones...Ray Okay wrote: They are huge compared to other teams for starters
No.. Absolutel not.FW17 wrote:So car changes camber when it turns?PlatinumZealot wrote:That drop in height of the brake duct is a function of the camber angle and the caster angle plus the distance of the duct away from the axis. The axis of rotation has an inclination to it so this will happen.Giando wrote:
That must be a first in F1
Does a teardrop looks old school to you? Thicker edges are not necessary draggier. If anything, a blade produces a vortex while rounded shape enables a laminar floor.Fer.Fan wrote:Compare body work Ferrari to Toro Rosso, I mean carbon fiber work. Edges on Ferrari are thicker, it looks like old school. TR body work looks more slim and air flow friendly. I could be wrong but...
It's an optical illusion.Giando wrote:Guys... something weird going on here with those brake cooling intakes...
