Yes, it is strange. It might be a narrow whiter strip on the not so white strip, but if you look closer at the bottom edge of the narrow strip, there is something that seems to be the edge of the wing element. But you are right, if it is day light comeing through it cant be the same principle as BMW or mclaren.horse wrote:It's weird that picture, which day was that photo taken? I can't find a similar picture. There is this one:
Regarding the big picture, it looks more like a long main element with a white strip, followed by a short second element. My feeling is, that if you could see daylight through it then it couldn't be a blown flap. I think you can definitely see daylight through the small, high, slit. Also, note that you can see the normal williams 'slot' in the flap element above the jack man's head. So I'd be surprised if this was a blowing slot in addition to the normal slot.tomazy wrote:I found one particulary interesting picture from Jerez testing. The rear wing on this picture has a white stip acros, and what looks like a gap in the middle of that strip? This is strange, becouse 3 part rear wings aren't legal?
What do you guys think?
http://img37.imageshack.us/img37/5568/djm1020fe82.jpg
So I reckon, not blown flap but long main element with stripe. High downforce setup perhaps?
EDIT: Although, if you at the end plate it looks like there is light coming through what I thought was a white stripe. However, I reckon this is just a reflection of the white paint rather than light getting through.
I also didnt come across any other similar pictures
