FrukostScones wrote:in Malaysia race used Vettel used test spec 2 and Webber used the Australian spec..
nope. Both used the test spec 2
FrukostScones wrote:Webber will continue with Australian spec and Vettel will test mod. test spec 1...
webber is using the Malaysia spec, which is end-of-Barcelona spec. Vettel will use the launch spec, with a few mods.
FrukostScones wrote:the modification will alter the exhaust spec, if they have to modify because of the exhaust (maybe the pipe and the angles stay the same but still a modified exhaust inmyho)
The quote said a modified spec, so it's not necessarily the exhausts. It could be, but not necessarily.
