Good that you posted that picture zgred. There are some Interesting differences between this and the leading Redbull.
Mp25 not so good on the street circuit i guess. Could have to do with the increased rideheights required for the bumps, worse when there's no fuel in the car."On that last lap I literally got everything that was in the car, there was really nothing left," said Hamilton.
"So clearly the Red Bulls have quite a lot more downforce, specially in the middle sector - they're like half a second faster than me.
"Literally, I touched all the barriers I could touch and used all the road I could use, so I'm happy with my performance."
I think that was Mark Hughes on one of the autosport magazines. He was saying that because Mclaren's diffuser is so enormous and complicated, they were having a hard time finding sufficient airflow to feed it. In comparison, red bull's diffuser is much simpler, and less prone to stall.raymondu999 wrote:
Also, I heard somewhere that the MP4-25's diffuser was more prone to stall when at a higher ride height then, say... the RB6's diffuser, meaning they probably had less downforce than they should have
Expect this diffuser to change multiple times this year, because McLaren have fouled up. The automatic assumption this year from many has been that you would strap the biggest double diffuser on the back of the car which is why many were suprised that Red Bull still had their pull rod rear suspension. However, McLaren's engineers have been shown in no uncertain terms that that assumption is bollocks. It's about managing the airflow into the rear diffuser to make it as efficient as possible. Red Bull have done it, Ferrari have designed with that in mind and Renault have done that. However, it's difficult to see what McLaren can move around at the back of that crowded car to do that. They need to chop the rear off that car and design a new one basically. Mechanically speaking, they clearly had some balance issues with the car in slow corners, and as I'd said many pages back in this thread when I got panned, packaging and balance were going to be the dominant variables.wesley123 wrote:the diffuser changed once again at mclaren? The central part wasnt on it before, only in the start of 2009. Also it sems the diffuser extends alittle bit higher and wider
the key to low CofG is not really parts positioning as low as possible the key is having the lightest car of all wich opens the window of placing ballast .the more ballast you need to add the lower your CofG potentially is.With high nose concept the CofG without ballast for the font half of the car must be at or around hub height ...with now all aluminium uprights and aluminium calipers the advantage of placing the caliper on the bottom of the upright seems to be slim....wesley123 wrote:well, as it seems we are going to see anoher brand new car for mclaren next year with the ban of the multideckers. Next year it is going to be as much downforce fron what you can get and a really low CofG. Teams have offered alot of CofG to get an much bigger diffuser, and that is something where the Red bulls have an advantage, an extremely low CofG, wich others lack. For example ferrari with their engine mounting, Renault because of their enormous diffuser etc.
