Red Bull RB8 Renault
RB7ate9
RB7ate9
Re: Red Bull RB8 Renault
The 1st practice sees Webber with B-Spec, while Vettel has exhausts super tight to the center line (exhausts exits are butt up to the coke bottle). It looks like a variation on the A-spec.
His speed 297.8 kph through the trap. Hasn't done a full lap yet.
Webber has set 1:39.558.
3:43a GMT
Vettel does not appear to have the central pillar.
Edited for Poor Temporal Maths
Crucial_Xtreme
Crucial_Xtreme
404
New RB8 Rear Wing
banibhusan
Are they using this new pillar to activate the DRS flap?
Hail22
144
banibhusan wrote:Are they using this new pillar to activate the DRS flap?
Yes, or so Ted Kravitz reckons!
Gilles Villeneuve
satlan
satlan
According to Ted, yes it does. But they were acting like this was something new, but didn't Williams or Mclaren do this last year?
Ferraripilot
21
It looks as if the second element is slightly larger as well. Wonder why they went with a central pylon to activate DRS...... perhaps they didn't want any of the changing hydraulic mechanism that high?
Crucial_Xtreme
Crucial_Xtreme
404
Ferraripilot wrote:It looks as if the second element is slightly larger as well. Wonder why they went with a central pylon to activate DRS...... perhaps they didn't want any of the changing hydraulic mechanism that high?
Kravitz suggests CoG gain.
rayden
rayden
99% of what comes out of ted's mouth is garbage :lol:
take it with a bucket of salt.
Lycoming
Lycoming
106
centre pylon was pretty common in at least the first half of last year. Not really good to have all sorts of stuff going on on the low pressure side of a wing though.
bhall
bhall
244
Indeed. Ferrari started with such a solution, but binned it pretty quickly in favor of Red Bull's solution. Weird to now see the ol' switcheroo.
But, it does make a little sense with the longer chord of the flap. The "pod," or whatever it's called, would interfere with the air flow to a place they're clearly trying to enhance.
I highly doubt it has anything to do with CoG, though.
EDIT: Come to think of it, Ferrari made that switch when they introduced a rear wing with a short-chord flap. That strongly suggests they're related.
RB7ate9
RB7ate9
Webber is running the pillar under the RW. Odd. 1:38.977.
What are the regulations regarding the size of materials beneath the rear wing? It's not big enough, I don't think, to act as some additional yaw-control surface.
raymondu999
bhallg2k wrote:Come to think of it, Ferrari made that switch when they introduced a rear wing with a short-chord flap. That strongly suggests they're related.
Same thing with McLaren.
Merc started off last year already with their hidden actuator though.
Anyone have shots of the 2 sidepod specs?
失败者找理由,成功者找方法
bhall
bhall
244
Might see more teams go to a Mercedes setup, too. I think all of these longer chords are being introduced because Daffy Ducts erase the penalty they inflict on DRS efficiency. So, if they've got thick end plates anyway, might as well shove a servo or two in there as well.
240
ringo wrote:The car is quite good. I don't know how good the drivers are.
Webber had many fastest laps at malaysia. This car is not slow by any means.
To be knocking on the podium with only mclaren faster than you is definitely not a failure.
The car simply doesn't have the qualy pace it used to. It also seems last year's car spoiled the drivers. Vettel is saying it's not easy to drive for some reason.
China will show that the car is still good, though i think they need a better exhuast solution or a reversion.
Hmm i think redbull need better conditions to compare the two solutions. I think the older is more predictable and consistent. The newer one is probably better for raw downforce numbers, as Webber is showing. However i think the old exhaust is probably a better choice in Vettel's case.
Forza
238
RB8 had the center pillar at some point at winter testing. Image
