Hello Uniflow.
You write:
“Manolis, the KTM system (my YZ unit copied by KTM) will archive between 14 and 21% fuel savings over a standard carburetor. We have tested our TPI YZ against a standard YZ to get these results. I built and tested this while KTM were still working with Orbital on their direct injection.”
According the DirtBikeTest (
https://dirtbiketest.com/fresh-dirt/201 ... sxs0tXc.97 ) : “fuel consumption is claimed to be 20-30% improved” in the KTM TPI / 2018
You also write:
“ Knocking out the pulse tuned exhaust will render your engine to lawn mower use, that's what will happen if you shut the exhaust port off so early. No doubt someone else here has pointed that out I'm just reminding you. That reverse pulse from the pipe is very desirable, after transfer is closed.”
Even so, it would be a cleaner lawn mower engine (aren’t the emissions the worst weakness of the 2-stroke engines? This is the problem the PatATi, the PatATeco and the PatATE designs try to solve).
It would be, also a lawn mower engine needing substantially less lubricant (unless the, by far, lower peak temperatures on the cylinder around the exhaust port area, and on the piston side that slides over the exhaust port, of the PatATE are not strong advantages over yours / KTM’s / Rotax’s TPI and conventional 2-stroke designs.
It would be, also, a lawn mower engine providing substantially more time from the moment the exhaust closes to the moment the combustion happens, which means there is time for better mixing / preparation, capability for higher revving, more efficient combustion.
On the other hand, think that the 4-strokes are stronger than the 2-strokes (as regards the quantity of air trapped into the cylinder per induction cycle) without needing a tuned exhaust.
Take the Ducati Panigale 1199 that makes 110mN/lit specific torque.
This requires a quantity of, say, 110 units of air to be trapped in the cylinder per lit of engine capacity, after each induction cycle.
Now take the KTM EXC300 / 2018 that traps, per induction cycle, less than 80units of air into the cylinder per lit of engine capacity.
This is less than 3/4.
Imagine a 2-stroke with the breathing capacity “per induction cycle” of the Panigale.
At the same revs it would make more than 35% more power than the current 2-strokes.
Thanks
Manolis Pattakos
